I want to configure SRST for one of branch offices.Had a query if "dialplan-pattern" command is sufficient to route incoming PSTN calls to the IP phones in SRST mode.DID range for example is 1234 13XX.Extensions are in range 13XX.Also will the command take care of caller id for outgoing calls?
application
global
service alternate default
ccm-manager fallback-mgcp
call-manager-fallback
max-conferences 10 gain -6
transfer-system full-consult
timeouts interdigit 4
ip source-address 10.XX.XX.XX port 2000
max-ephones 240
max-dn 960
dialplan-pattern 1 123413.. extension-length 4 extension-pattern 13..
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
preference 1
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
Let me know if the above configuration is sufficient for SRST and do I need to configure additional translational profile/rule for call routing.Port 0/0/0 is connected to local PSTN.
KMS
