Community Member
SRST DID translation mapping
I have callmanager 4.2, with my Voice router as an voice router is an H323 gateway...i have 1:1 translations for about 20 DIDs setup in my call manager (IE: 1234 --> 4321) can i setup SRST so that inbound DID still works when the callmanager fails or is down. I want outside users to be able to call 1234 and it ring 4321 in SRST mode. Again i have about 20 DIDs that are 1:1 mapped..
Thanks in advance, greatly appreciated
Re: SRST DID translation mapping
The translation can be performed on the gateway or on the Cisco CallManager.
If you have a Cisco IOS? Software gateway, a translation rule can be created and applied to the outbound Voice over IP (VoIP) dial peer. The following is an example configuration:
translation-rule 1
rule 1 ^0760 7300
dial-peer voice 10 voip
translate-outgoing called 1On Cisco CallManager, make a translation pattern and change the called party number from 0760 to 7300.
Community Member
So if the provider is sending me 4 digits..i could do this..please let me know if im following you correctly..
translation-rule 1
rule 1 /1000/ /2000/
voice translation-profile To-CM
translate called 1
dial-peer 1 voip
translation-profile incoming To-CM
destination-pattern 2...
voice-class codec 1
session target ipv4:
dtmf-relay h245-alphanumeric
ip qos dscp cs3 signaling
I would then delete translation patterns off of the CManager.
is this correct?
The effect i want is to get the provider 1... DIDs translated to 2000s (which is our internal numbering plan) and send the 2000s after translated to the Callmanager for routing to the appropriate phone.
Thanks for all your help
