SRST doesnt work with CCM4.3 AND IP PHONES 7945 &7941
HI,
i have a CCM 4.3(1) working with 7945 and 7941 ip phones working, and a 2851 router with SRST, but when i see the ip phones supported by the SRST router, i only see other phones different. i have already configured the SRST but i does not work, does anyone know how to solve the problem?
Re: SRST doesnt work with CCM4.3 AND IP PHONES 7945 &7941
do they all have the SRST reference?
do you have all the proper routing to reach the SRST?
are they on the same vlan as working phones?
do you have the required SRST version and firmware loads?
Cisco Unified Survivable Remote Site Telephony
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_device_support_tables_list.html
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
hi, thanks a lot for your answer, but i have alreday checked all these points. i send you more information about the TOip solution that i am working in.
a/yes they do.
a/the SRST router is the same voip gateway (pstn connections)
a/ the router is on the same vlan where the CCM is working in.
these are the firmware:
COBOG-2851-VG1#sh call-manager-fallback
CONFIG (Version=4.1(0))
Version 4.1(0)
system message primary Sistema de Respaldo Activado
system message secondary Sistema de Respaldo
Limit number of DNs per phone:
7910: 36
7935: 36
7936: 36
7940: 36
7960: 36
7970: 36
Log (table parameters):
max-size: 150
retain-timer: 15
why i dont see the 7941 and 7945???
the router IOS is
flash:c2800nm-adventerprisek9-mz.124-15.T4.bin
and the ip phones firmware are:
7941 SCCP41.8-3-3SR2S
7945 SCCP45.8-3-3SR2S
these are higher that the document recomends, so i suposed that firmware version will work.
the CCM Version is, 4.3(2)
thanks a lot!
Hall of Fame Super Red
Hi Giovanni,
Just to add a note to the good info from Jaime, you need a minimum of SRST 4.1 to support these two IP Phone models;
Cisco Unified SRST 4.1 Supported Firmware, Platforms, Memory, and Voice Products
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/requirements/guide/srs41spc.htm
Hope this helps!
Rob
307
