SRST Doubt
Fellows
I got a question if you can help me. We purchase a 2951 router (C2951-CME-SRST/K9) for SRST, we also purchase 225 licenses for this purpose. After this we upgraded the IOS, passing from a c2951-universalk9-mz.SPA.151-4.M1 to c2951-universalk9-mz.SPA.152-1.T1, and after we ran a show version and now says C2951-UNIVERSALK9-M (not C2951-CME-SRST/K9).
My doubt is:
- I have to upload the licenses to the gateway?, and if i have to, how is the procedure?
- Or i lose the SRST capacity with the upgrade of IOS and i have to go back to the original IOS?
Thanks in advance
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
SRST Doubt
Hi there,
When you purchase the 2951 router and see (C2951-CME-SRST/K9) for SRST:
Cisco ISR G2 CME-SRST bundles for the 2900 Series router that come with the entry-level PVDM3, UC technology license, and right-to-use licenses for 25 seats of Cisco Unified CME or SRST
The new device comes with 60 days evaluation licens and changes to "Right to Use".
IOS upgrade needs Reboot and rebooting the device after the evaluation period, will need activation:
Please follow the steps from the below link:
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html#wp1155517
++ The above link also has activating evaluation license
Hope the above helps.
Thanks and Regards
Prashanthi Velpula
SRST Doubt
Below is more information on ISR2 ( 2900 ) Licensing:
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985_ps10537_Products_White_Paper.html#wp9001359
Activating CME-SRST Feature License
The ISR G2 comes with a 60-day evaluation license. After 60 days, the license changes to "right to use". The customer is required to pay for the CME-SRST feature license which is valid for 12 years
Evaluation Licenses
Evaluation licenses are also temporary, and you use them to evaluate a feature set on new hardware
You obtain evaluation licenses from the Cisco licensing portal: https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet?DemoKeys=Y
Note You must go to the Cisco Product License Registration portal prior to the expiration of the evaluation license to upgrade the license status.
http://www.cisco.com/en/US/docs/ios/csa/configuration/guide/csa_overview_support_TSD_Island_of_Content_Chapter.html#wp1067426
So, ultimately you will need to order the SRST feature and then load the corresponding license key PAK when received.
Licensing functionality is working as per design here.
Cme-srst licenses are honor based and hence you have to just accept the EULA.
After the 60 days of EvalRightToUse the license will change to "right to use" for 12 years Licensing functionality is working as per design here.
After all the above, you still have any further queries, please feel free to contact " licensing@cisco.com "
Thanks and Regards
Prashanthi Velpula
SRST Doubt
Hi there,
Thanks and Regards
Prashanthi Velpula
SRST Doubt
Thanks for the answer Prashanthi
That's means that i have to go to the www.cisco.com/go/license and enter the PAK numbers to get the SRST licenses and then upload to the router and will get the srst feature?
Thanks in advance
Best regards
SRST Doubt
Evaluation Licenses
Thanks and Regards
Prashanthi Velpula
SRST Doubt
Thanks for all the help
SRST Doubt
Glad to know your queries have been answered.
Prashanthi Velpula
1187
