SRST - Enabling Call Transfer - What Config
I have the folling config for Call Manager fallback, but I can not transfer a received call from one local extension to another, I just get busy tone,
call-manager-fallback
max-conferences 24 gain -6
transfer-system local-consult
limit-dn 7940 2
limit-dn 7960 2
ip source-address 10.69.22.2 port 2000
max-ephones 248
max-dn 248 dual-line
dialplan-pattern 2 6356.. extension-length 5 extension-pattern 256..
dialplan-pattern 3 6357.. extension-length 5 extension-pattern 257..
transfer-pattern 256..
transfer-pattern 257..
huntstop channel
alias 1 635200 to 25602
alias 2 635202 to 25602
alias 3 635223 to 25602
alias 4 635238 to 25602
alias 5 623250 to 25602
alias 6 635239 to 25602
alias 7 623251 to 25602
alias 8 635227 to 25602
alias 9 635233 to 25602
alias 10 635229 to 25602
alias 11 635228 to 25602
alias 12 635240 to 25602
alias 13 635244 to 25602
alias 14 635210 to 25627
alias 15 635218 to 25627
alias 16 635243 to 25627
alias 17 635242 to 25627
alias 18 623267 to 25627
alias 19 635241 to 25627
alias 20 623266 to 25627
alias 21 635226 to 25627
alias 22 635220 to 25627
alias 23 635215 to 25621
alias 24 635249 to 25621
alias 25 635247 to 25621
alias 26 635248 to 25621
alias 27 635212 to 25631
alias 28 623260 to 25631
alias 29 623259 to 25631
alias 30 623258 to 25631
alias 31 635216 to 25628
alias 32 623264 to 25628
alias 33 623263 to 25628
alias 34 623262 to 25628
alias 35 635235 to 25665
alias 36 635234 to 25640
alias 37 635203 to 25640
alias 38 635204 to 25650
alias 39 635224 to 25665
alias 40 635222 to 25665
alias 41 635225 to 25609
alias 42 635231 to 25658
alias 43 635201 to 25658
alias 44 635206 to 25658
alias 45 635207 to 25658
alias 46 635236 to 25658
alias 47 6356.. to 25602
alias 48 6357.. to 25602
alias 49 6232.. to 25602
alias 50 6352.. to 25602
translate called 100
moh All_in_the_Mind.ULAW.wav
time-format 24
date-format dd-mm-yy
Re: SRST - Enabling Call Transfer - What Config
transfer-pattern command restricts to what numbers you can transfer to. So you are allowed to transfer only to 256.. and 257.. So when you say other locations, are you trying to transfer this call externally to another location via PSTN ? THis would mean that when the user dials 25600 (say) it has to be translated by a num-exp or translation rule to the required PSTN number. Remember to add a 1 for long distance.
Sankar
PS: please remember to rate posts!
Call from the pstn calls at ext 25601, 25601 answer the call, then te user wants to transfer the external call from ext 25601 to ext 25602. When I loaded the above config I could not transfer the call.
173
