Community Member
Srst extension translation
Hi guys,
We have phones that with long extension. We are using last 4 digit for internal usage in CUCM operation. But in SRST mode, we could't operate last 4 digit instead of entire extension. We have to dial entire extension. It is possible to do something like translation in SRST mode ?
Baris.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Yes its possible by configuring translation profiles and using CME-SRST. You can also use the num-exp command as well.
Please rate useful posts.
Re: Srst extension translation
Hi Baris
yes , all possible , because your router on SRST is as CME you can do all. Please find the below and set an answers:-
1-Can you give an example?. and what will you need?.
2-Can you share with me your configuration?.
Thank you
Please rate all useful information
You can do translations even if not using CME-SRST, aka you can have it with call-manager-fallback.
This is an example from one of my customers that uses this.
voice translation-rule 50
rule 1 /^632\(....\)$/ /+632871\1/
rule 2 /4662010/ /0004640322010/
rule 3 /4665555/ /0004640325555/
rule 4 /^\+632\(.*\)/ /0\1/
rule 5 /^\+63\(.*\)/ /00\1/
rule 6 /^\+\(.*\)/ /000\1/
voice translation-profile SRST-IN
translate called 50
translation-profile incoming SRST-IN
Please remember to rate helpful responses and identify helpful or correct answers.
255
