SRST fail
I need some help in SRST. I have Callmanager Ver.5.12 and the remote office has Cisco ISR2851 running IOS spservicesk9-mz.124-9.T7. In the event of SRST, inbound and outbound call to the remote site fail. Debug q931 shows
*Feb 2 21:43:52.711: ISDN Se0/3/0:23 Q931: RX <- SETUP pd = 8 callref = 0x1D94
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x2181, '9173267515'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '3771'
Plan:ISDN, Type:Subscriber(local)
*Feb 2 21:43:52.723: ISDN Se0/3/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x9D94
*Feb 2 21:43:52.727: ISDN Se0/3/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x9D94
Cause i = 0x8081 - Unallocated/unassigned number
*Feb 2 21:43:52.807: ISDN Se0/3/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x1D94
*Feb 2 21:43:52.807: ISDN Se0/3/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref 4
Here is the Call-manager-fallback
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.107.100.4 port 2000
max-ephones 96
max-dn 192 dual-line preference 2
system message primary Network Outage
dialplan-pattern 1 416682.... extension-length 4
transfer-pattern .T
voicemail 12125919147
no huntstop
alias 1 4907 to 4907 cfw 4908 timeout 6
alias 2 4908 to 4908 cfw 4909 timeout 6
alias 3 4909 to 4909 cfw 4910 timeout 6
call-forward pattern .T
call-forward busy 12125919148
call-forward noan 12125919148 timeout 16
multicast moh 239.1.1.110 port 16400 route 10.107.100.4
Any help is appreciated.
Mark
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: SRST fail
That could certainly be the reason, I would suggest upgrading to 12.4.15T8.
Also, ensure your binding of SRST interface is to proper IP address:
"ip source-address 10.107.100.4 port 2000"
HTH,
Chris
Re: SRST fail
Unallocated/unassigned number - indicates that the 3771 number cannot be found, is there a phone with that DN that registered under SRST? Are you performing any further digit manipulation?
Can you post your entire config?
What do you get in q931 debug for outboud call?
Chris
Re: SRST fail
There is a phone with that DN. Outbound call fail and debug q931 did not show anyting. However I notice the sh ephone does not list out the model of phone I am using, 7965.
#sh ephone ?
7902 7902 phone status
7905 7905 phone status
7910 7910 phone status
7911 7911 phone status
7912 7912 phone status
7914 7914 phone status
7920 7920 phone status
7935 7935 phone status
7936 7936 phone status
7940 7940 phone status
7941 7941 phone status
7941GE 7941GE phone status
7960 7960 phone status
7961 7961 phone status
7961GE 7961GE phone status
7970 7970 phone status
7971 7971 phone status
H.H.H mac address
anl ANL port status
ata ata phone status
attempted-registrations Attempted ephone list
bri BRI port status
cfa registered ephones with call-forward-all set
dn Dn with tag assigned
dnd registered ephones with do-not-disturb set
login phone login status
offhook Offhook phone status
overlay registered ephones with overlay DNs
phone-load Ephone phoneload information
registered Registered ephone status
remote non-local phones (with no arp entry)
ringing Ringing phone status
sockets Active ephone sockets
summary Summary of all ephone
tapiclients Ephone status of tapi client
telephone-number Telephone number assigned
unregistered Unregistered ephone status
| Output modifier
Did some search in Google and notice the router's IOS 12.4-9.t7 may not support 7965 phone. I will upgrade the IOS and let you know if that fix the problem.
Mark
Re: SRST fail
HTH,
Chris
Re: SRST fail
I upgraded the router IOS to 12.4.15T8. SRST started to work.
Thanks.
Mark
227
