Community Member
SRST fallback fails for in/outbound calls on PRI
Hi Guys,
I have multiple site experiencing similar problems. I have 37xx routers with PRI working OK when running on CCM. When I fail the WAN SRST does not allow me to do in/outbound calls via the PRI line - I ge ta busy tone).
I am running IOS c3745-ipvoice-mz.123-8.T8.bin
The PRI works OK when running on CCM.
I have 6 digits DNs. I only use the last 2 digits from the DDI to route to DNs.
Please see config extract.
pri-group timeslots 1-31 service mgcp
interface Serial1/0:15
no ip address
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
call application alternate DEFAULT
voice-port 1/0:15
cptone GB
mgcp
mgcp call-agent 1.1.1.1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer cor custom
dial-peer voice 100 pots
preference 1
application mgcpapp
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 1/0:15
num-exp 67.. 1122..
call-manager-fallback
secondary-dialtone 9
max-conferences 8
limit-dn 7910 2
limit-dn 7940 2
limit-dn 7960 2
timeouts interdigit 5
ip source-address 3.3.3.3 port 2000
max-ephones 24
max-dn 15 dual-line
dialplan-pattern 1 1234567.. extension-length 6 extension-pattern 1122..
access-code pri 9T direct-inward-dial
call-forward busy 112260
call-forward noan 112260 timeout 30
Many thanks
G.
1 REPLY
Green
Re: SRST fallback fails for in/outbound calls on PRI
Please add:
ccm-manager fallback-mgcp
and after that when testing SRST check the status of the PRI circuit.
show isdn status
debug isdn q931 and debug voice ccapi inout are always helpful.
T otroubleshoot dial plan issues: debug voice dial peer.
289
