Community Member
SRST from the start
I went on a job interview and was asked what are the first two commands you put in the router for SRST. When the routers were set up for this I did it with a partner years ago (4 Years ago). Well i dident know the answer to the question and I have been searching for the answer. The person asking me said "once the commands are put in the do not show up on the config." I can not find these any place even though I have found alot on SRST.
Its good to get this down for my own general knowledge but I can seem to find this answer. Can some one tell me or point me in the best direction.
Chris
1 REPLY
Re: SRST from the start
There are three commands you need for a minimal SRST configuration -
call-manager-fallback
ip source address
max-ephones
max-dn
The values for max-ephones and max-dn are platform dependent. Refer here for more details -
http://my.safaribooksonline.com/158705258X/ch13lev1sec2
All these commands show up in the config.
You might be able to go back the prospective employer and argue the point :-)
136
