Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
SRST full E164 with + sign
Hi All,
there is a CUCM 8.5.1 with 6921 (SCCP) and 9971 (SIP) registered.
There is also a remote site with a 2951 (IOS 15.1.3), GW set as SRST reference.
All phones are registered with full E.164 numbers (with + sign at the begining!) on CUCM, and can call each other with the last 3 digits!
In case of WAN failure phones register with the SRST GW with their full E.164 number (with the plus sign). How can I ensure that phones also could call each other with 3 digits in SRST mode??
I have tried num-exp, dialplan pattern without any luck... Perhaps the '+' sign cause this issue?
Thanks for your help!
Tibor
1 REPLY
you can use the translation-profiles in the ephone-dn template , this will solve the issue
num exp command will not work out for "+" sign...
724
