Highlighted
Community Member
SRST hairpin
How can I disable calls hairpin on a SRST router over PRI?
1 ACCEPTED SOLUTION
Green
Re: SRST hairpin
Could you please clarify?
The scenario?
Incoming call not able to get routed to PSTN again?
You can use CoR in the incoming dial-peer and in all the outgoing dial-peers not include that member of the CoR List
1 REPLY
Green
Re: SRST hairpin
The scenario?
155
