SRST HELP - what am i doing wrong..?
Hi All - i'm doing my first deployment of CUCMBE 6.1 with CUPS. Everything running well... except SRST.
The handsets say:
1) x.x.x.x - callmanager 1 ACTIVE
2) x.x.x.x - callmanager 2 SRST
That all looks good.
My router looks like:
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.37.254.14 port 2000
max-ephones 96
keepalive 10
The source address here is the interface on the ISR router itself. Is that correct?
When i power down the CUCM the phones go blank and not into 'fall back mode'.
All help apperciated!
Thanks - James.
Re: SRST HELP - what am i doing wrong..?
James,
max-dn 96
This is a required command before things in srst will register.
HTH, please rate helpful posts..
Chad
Thanks Chad
I have the phone now saying "fall back" however, i don't have any buttons etc.. nothing saying 'Redial, New Call etc...'
Naturally, i also can't dial out!
The dialing out is probably due to the dial plan, but any ideas on the soft buttons?
Thanks - JH
Please paste the entire config...
also did you have the gateway registered to CCM before you added max-dn. it needed to register SRST with CCM and srst properly configured and dl the TFTP loads... Else you might get the blank stuff you have. Do you see dn numbers on the phones?
I would...
1.) reload router let it connect to CM and register phones normally.
2.) go into srst verify fnctinoality.
3.) have you configured H323, is this mgcp? then you need to configure h323 fallback!.
Chad
Also,
add these under call-manager-fallback
dialplan-pattern 1 760688.... extension-length 4 <--whatever your did ranges are here
transfer-pattern .T
call-forward pattern .T
Thanks Chad -
GMOSYDISR01#sh run
Building configuration...
Current configuration : 2065 bytes
! Last configuration change at 14:04:59 SYD Wed Jun 25 2008 by gmotech
! NVRAM config last updated at 14:05:01 SYD Wed Jun 25 2008 by gmotech
version 12.4
hostname GMOSYDISR01
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret
enable password
no aaa new-model
resource policy
clock timezone SYD 10
network-clock-participate wic 0
ip cef
no ip domain lookup
stcapp ccm-group 1
isdn switch-type primary-net5
voice-card 0
no dspfarm
username gmotech password 0 l0seme365
controller E1 0/0/0
pri-group timeslots 1-20 service mgcp
controller E1 0/0/1
interface GigabitEthernet0/0
ip address 10.37.254.14 255.255.255.0
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip route 0.0.0.0 0.0.0.0 10.37.254.1
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0:15
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager mgcp
ccm-manager config server 10.37.254.10
ccm-manager download-tones
mgcp
mgcp call-agent 10.37.254.10 service-type mgcp version 0.1
mgcp profile default
dial-peer voice 1 pots
destination-pattern 0....
dial-peer voice 10 pots
service mgcpapp
max-ephones 96
max-dn 96
keepalive 10
line con 0
line aux 0
line vty 0 4
password l0seme365
login local
scheduler allocate 20000 1000
ntp clock-period 17180110
ntp server 10.42.10.11
end
Can you repost your new full config, now thats it registered to CM again, it should show more mgcp packages ;)
Thanks Chad
Thanks - JH
i would sujest you to make it not gateway srst but CME srst in this case you need to define phones as you are useinf CME then you add buttons, lines DNs for each phone
in this case when your phons fall-back to srst mode will use the configured info
rate if help full
ccm-manager mgcp
ccm-manager config
ccm-manager fallback-mgcp
application
global
service alternate Default
Add that. Also you need to configure some H323 peers for dialing out.
that will enable h323 fallback. Make sure that your reference is set on the CM device pool.
Chad
also give me
sh ephone reg
sh call-manager-fallback
sh ccm-manager
Chad
add
H323-Services
voice services voip
allow-connection h323 to h323
allow-connection h323 to sip
allow-connection sip to h323
allow-connection sip to sip
dial-peer voice 1050 pots
destination-pattern 91[2-9]..[2-9]......
port 0/0/0:15
forward-digits 11
description *** US / Long Distance ***
add this to enable LD Calling
lastly please register this via mgcp and do ccm-manager when its registered and verify its registered. Then put it into fallback..
Chad
GMOSYDISR01#sh ccm-manager
MGCP Domain Name: GMOSYDISR01
Priority Status Host
Primary Registered 10.37.254.10
First Backup None
Second Backup None
Current active Call Manager: 10.37.254.10
Backhaul/Redundant link port: 2428
Failover Interval: 30 seconds
Keepalive Interval: 15 seconds
Last keepalive sent: 15:10:19 SYD Jun 25 2008 (elapsed time: 00:00:05)
Last MGCP traffic time: 15:10:19 SYD Jun 25 2008 (elapsed time: 00:00:05)
Last failover time: None
Last switchback time: None
Switchback mode: Graceful
MGCP Fallback mode: Enabled/OFF
Last MGCP Fallback start time: 15:05:05 SYD Jun 25 2008
Last MGCP Fallback end time: 15:07:07 SYD Jun 25 2008
MGCP Download Tones: Enabled
Custom Tone 1 : Default (United States)
Backhaul Link info:
Link Protocol: TCP
Remote Port Number: 2428
Remote IP Address: 10.37.254.10
Current Link State: OPEN
Statistics:
Packets recvd: 22
Recv failures: 1
Packets xmitted: 24
Xmit failures: 0
PRI Ports being backhauled:
Slot 0, VIC 0, port 0
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading Tone XML file
Configuration Download statistics:
Download Attempted : 3
Download Successful : 3
Download Failed : 0
Configuration Attempted : 1
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command:
FAX mode: cisco
Configuration Error History:
GMOSYDISR01#sh ephone
ephone-1 Mac:0021.55D4.C0C4 TCP socket:[3] activeLine:0 UNREGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:12
IP:10.37.11.250 51989 Unknown 435 keepalive 46 max_line 0
ephone-2 Mac:001D.705F.A571 TCP socket:[1] activeLine:0 UNREGISTERED
IP:10.37.11.216 49472 Unknown 435 keepalive 50 max_line 0
ephone-3 Mac:0021.5554.A720 TCP socket:[4] activeLine:0 UNREGISTERED
IP:10.37.11.240 50034 Unknown 435 keepalive 50 max_line 0
ephone-4 Mac:001D.705E.AE5B TCP socket:[2] activeLine:0 UNREGISTERED
IP:10.37.11.222 49665 Unknown 436 keepalive 50 max_line 0
GMOSYDISR01#sh ephone reg
No ephone in specified type/condition.
alright thats registered to CCM. Now add all those commands and put it back into SRST and try dialing out
sh ephone reg
sh ccm-manager
You should be able to dial long distance, and hopefully have your buttons
The phones have registered :
ephone-1 Mac:0021.55D4.C0C4 TCP socket:[3] activeLine:0 REGISTERED in SCCP ver 15 and Server in ver 5
IP:10.37.11.250 51989 Unknown 435 keepalive 10 max_line 0
ephone-2 Mac:001D.705F.A571 TCP socket:[1] activeLine:0 REGISTERED in SCCP ver 15 and Server in ver 5
IP:10.37.11.216 49472 Unknown 435 keepalive 8 max_line 0
ephone-3 Mac:0021.5554.A720 TCP socket:[4] activeLine:0 REGISTERED in SCCP ver 15 and Server in ver 5
IP:10.37.11.240 50034 Unknown 435 keepalive 8 max_line 0
GMOSYDISR01#sh call-manager-fallback
CONFIG (Version=4.0(0))
Version 4.0(0)
For on-line documentation please see:
www.cisco.com/univercd/cc/td/doc/product/access/ip_ph/ip_ks/index.htm
max-ephones 96
max-dn 96
dspfarm units 0
dspfarm transcode sessions 0
huntstop
dialplan-pattern 1 827499... extension-length 3
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line mode is single
time-format 12
date-format mm-dd-yy
timezone 0 Greenwich Standard Time
transfer-pattern .T
keepalive 10
timeout interdigit 10
timeout busy 10
timeout ringing 180
timeout ringin-callerid 8
caller-id name-only: enable
Limit number of DNs per phone:
7910: 36
7935: 36
7936: 36
7940: 36
7960: 36
7970: 36
Log (table parameters):
max-size: 150
retain-timer: 15
local directory service: enabled.
Primary Down 10.37.254.10
First Backup None
Second Backup None
Current active Call Manager: None
Last keepalive sent: 15:24:49 SYD Jun 25 2008 (elapsed time: 00:03:13)
Last MGCP traffic time: 15:24:34 SYD Jun 25 2008 (elapsed time: 00:03:28)
MGCP Fallback mode: Enabled/ON
Last MGCP Fallback start time: 15:25:20 SYD Jun 25 2008
Backhaul/Redundant link is down
FAX mode: cisco
However, my phones are still dead. They just say "CM Fallback serivce operating".
Thanks for your help this far!
Can you please repost your config.. I am going to lab this, give me about 20 minutes, I have this gear at my house..
If you think any of this stuff helps, we at netpro suggest rating it!
Chad
Thanks mate - you'll be getting a 5 star rating!
GMOSYDISR01#sh run
Current configuration : 2651 bytes
! Last configuration change at 15:37:02 SYD Wed Jun 25 2008
version 12.4
hostname xxx
boot-start-marker
boot-end-marker
card type e1 0 0
enable secret xxx
enable password xxx
no aaa new-model
resource policy
ip cef
no ip domain lookup
stcapp ccm-group 1
voice-card 0
no dspfarm
application
global
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
duplex auto
speed auto
no mop enabled
no ip address
shutdown
duplex auto
speed auto
no ip address
encapsulation hdlc
isdn protocol-emulate network
no cdp enable
ip http server
control-plane
voice-port 0/0/0:15
cptone AU
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config
mgcp
mgcp call-agent 10.37.254.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
service mgcpapp
max-ephones 96
max-dn 96
transfer-pattern .T
keepalive 10
line con 0
line aux 0
line vty 0 4
password xxx
login local
ntp clock-period 17180107
end
GMOSYDISR01#
put in that dial peer for long distance, you may need to have it to ungrey the buttons :p may need a valid dial peer
Turns out my brand new ISR router was running the wrong version of IOS. Changed it and all is well. Thanks for all your help.
- James.
no probs, glad it is working... btw from what version was the error to what version fixed it!
This is what i had: c2800nm-advipservicesk9-mz.124-9.T7.bin
This is what i needed: c2800nm-advipservicesk9-mz.124-15.T5.bin
Thanks - JH
My standard IOS, and CVP Base IOS (irrelevent but for a reason I believe) is 12.4(15)T4 and I believe this is the minimum IOS anyone should be running right now!!!
Chad
How do you test SRST? Do you use ACL or static route? Can you show commands that are used for falling router in the SRST mode?
426
