SRST help
    Hi guys,
I'll need some help configuring SRST.
I've set the call-manager-fallback command like this:
secondary-dialtone 9
max-conferences 12 gain -6
transfer-system full-consult
ip source-address 10.10.0.2 port 2000
max-ephones 300
max-dn 500
system message primary SRST Fallback Active
system message secondary SRST Fallback
dialplan-pattern 1 04222..... extension-length 5
I can talk between DN but I can't get call outside.
I have a PRI link
Is there anything else that I have to configure ?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: SRST help
you must configure a pots dial peer for outgoing call
example:
dial-peer voice 1 pots
desc outgoing SRST
destination-pattern 9T
port 0/0/0:15
Re: SRST help
example:
desc outgoing SRST
port 0/0/0:15
Re: SRST help
I configured it but still not working.
dial-peer voice 11 pots
direct-inward-dial
port 0/3/1:15
forward-digits all
Re: SRST help
what say
debug isdn q931
if you dial a number to PSTN?
Re: SRST help
i've set the debug but nothing happens when I try to call.
I solved it. The port setting was not right.
Re: SRST help
Hi. I've the same problem.
Can You explain me what did You corect in port settings.
When my SRST router has been restarted due to power interraptions I've loss access to PSTN.
thank's
Alex
Re: SRST help
Hi Alex,
Well, the serial port that I specified was wrong. I checked the router and set the correct port.
Please put your config here maybe I can help.
Adrian
432
