SRST inbound H323 calls after failover
Inbound calls to my FXO do not work after failover as they are matching the phone "dial-peer" as a higher priority to my voip dialpeer so the call is trying to ring a phone that is unregistered prior to getting to the dial-peer that runs over to the CM. Probably an easy solution but I'm not coming up with it right now. I am using SRST mode aut provision all - do I have to change this or is there another way to force the dial-peer to be a higher priority.
1 REPLY
Green
Re: SRST inbound H323 calls after failover
there is a preference command for dn under callmanager fallback.
can you post the configuration.
and the debug voice ccapin inou for this test call so we can see what exactly is matching and why.
254
