SRST International numbers
Ahmed Awida
Hi,i have problem .In srst mode all the calls get connected successfuly except the international numbers and the reason is the the last digit of the number
is getting stripped which is very strange !
dial-peer voice 70 pots
description SRST International
destination-pattern 9810T
prefix 810
preference 8
trunkgroup Three_E1_ROS
translation-profile outgoing Caller_ID_SRST
Help is so appreciated.
Thanks.
casa_far
It's very strange, If It's possible, could you post the debug isdn q931 and the debug voice ccapi inout of a call during the srst state and indicating the exact number you dialed ?
Thanks!
Thanks Fracesco,i think i found the answer to my question and it's a more exact match dialpeer.I will check on Monday and if this does not help,i will update the post.
Use debug voice dialpeer to identify which dial peer is being matched.
Chris
