SRST Issue
inayshtut
I am having an issue with SRST. We are using 5 digit extensions within the building, the first digit for this particular site is a 9. However, we are translating it to a 1 when in regular more using a translation patern. What I am trying to do is translate it in SRST as well. Is there any way to do this outside of using an Alias command?
Any help would be appreciated!!! Thanks in advance.
val.mintchev
Level 4
Level 4
Greetings,
You should be able to use voice translation-rules and apply voice translatin-profiles under the incoming dial-peer for SRST mode.
example could be:
voice translation-rule 1
rule 1 /^\(9\)\(....\)$/ /1\2/
voice translation-profile SRST_Incoming
translate called 1
and apply under the corresponding dial-peer.
You could also try to use the " dialplan-pattern" under the SRST configuration and manipulate the digits.
Val
