SRST Issue.
Hey Guys,
Trying to get the SRST working with no luck. CUCM-->2921(H323)-->PRI
Here is the config on the router..When I shut the call manager service on CUCM, cipc tries to register to the router.
card type e1 0 0
logging buffered 51200 warnings
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
voice-card 0
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g722-64
codec preference 4 g729r8
video codec h264
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 1
rule 1 /^6679/ //
voice translation-profile OUTGOING
translate called 1
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 0/0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 10.200.132.5 255.255.252.0
duplex auto
speed auto
h323-gateway voip bind srcaddr 10.200.132.5
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
control-plane
voice-port 0/0/0:15
mgcp profile default
dial-peer voice 1 pots
destination-pattern 9.T
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 voip
translation-profile outgoing OUTGOING
destination-pattern .
session target ipv4:10.200.132.10
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 10.200.132.5 port 2000
max-ephones 110
max-dn 150
application default
Varadarajan.R
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: SRST Issue.
Great, please mark question as answered,
Chris
SRST Issue.
OK, what is not working? What is happening?
Chris
SRST Issue.
Hi Chris,
When I shut the CUCM down, the phone is not registering to the Router.
Varadarajan.R
Re: SRST Issue.
Does it have SRST reference defined?
Are you running SCCP or SIP load?
SRST Issue.
Yes, SRST ref is defined. Running SCCP load.
SRST Issue.
Can you post "debug ephone register"?
Chris
SRST Issue.
I shutdown the call manager to get a few logs, but nothing.
I see nothing on for "debug ephone register"
VR
SRST Issue.
If you browse the IP address of the phone and go under Network Setup do you see the SRST reference there?
Can you ping the SRST router from the CUCM or the phone VLAN?
Chris
SRST Issue.
Yes, I can see the router IP Listed as SRST and aswell as on the "Device Config" on the phone.
I can ping it ofcourse, also the router is registered as a h323 gateway on cucm and pri calls are thru it.
VR
SRST Issue.
Are other device types registing to it?
You may want to do a wireshark trace on your PC to see what the IPC is doing.
Chris
Re: SRST Issue.
No, none of em is.
I do see the request sent out to the router. I am still learning TS. Pls help out, I have attached it.
Varadarajan.R
SRST Issue.
Hi Chris,
I wrote the config and restarted the router and it started working. Didnt change a thing.
The phone has registered with the router.
I am not able to dial and working on a dial plan.. Do i need anything more ?
VR
SRST Issue.
What are you dialing? PSTN or internal numbers?
If PSTN please post "debug isdn q931" and "debug voice dialpeer"
HTH, please rate all useful posts!
Chris
SRST Issue.
Hi Chris,
I am dialling PSTN and it works now.
I have the below two dial-peers. I had "destination pattern ." on voip and had to remove it. But what will happen now when I turn the CUCM back on. Also what should I do for Internal Numbers ?
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
voice-class codec 1
no vad
VR
Re: SRST Issue.
Chris
SRST Issue.
Hi Chris,
Thanks a lot for the support.
But what should I do for internal dialling ? And I removed "destination-pattern ." from the voip dialpeer. What happens if I turn on the CUCM ?
Thanks again.
Varadarajan.R
Re: SRST Issue.
You need destination pattern on the VoIP calls to point to CUCM under normal condition, it should be defined based on how many and what digits you receive from telco.
As to internal dialing it depends on your dial plan which you omitted details for, ie is it variable length that you want to allow abbreviated dialing, etc. provide all details please, the way you would handle this would be via translation rules and profiles applied under call-manager-fallback.
Chris
265
