SRST License upgrade
We have received the 3925 router with SRST license, can any body guide me how to upgrade current license to the SRST.
The SRST licenses we received separately as document as follow:
Product                               Description                                              Entitlement Qty
L-FL-CME-SRST-100=         CME or SRST - 100 Seat E-DeliveryRTU     1
Ali
Hall of Fame Super Silver
Do you need to buy more licenses?  Or are you asking how to apply the license?
SRST licenses are not enforced, they are righ to use licenses, all you need to do on the GW is accept the end user agreement and reboot the gateway.
HTH,
Chris
I am asking on how to apply it please see below;
Router#show license detail cme-srst
% Error: No license for cme-srst found - License feature not found
Router#sh license udi
Device#   PID                   SN              UDI
*0        C3900-SPE100/K9       FOC14351328     C3900-SPE100/K9:FOC14351328
Router(config)#license accept end user agreement
% Invalid input detected at '^' marker.
Router#sh flash
-#- --length-- -----date/time------ path
1     55277232 Sep 21 2010 10:20:58 c3900-universalk9-mz.SPA.150-1.M3.bin
2         2903 Sep 21 2010 10:35:04 cpconfig-39xx.cfg
3      2915328 Sep 21 2010 10:35:22 cpexpress.tar
4         1038 Sep 21 2010 10:35:34 home.shtml
5       115712 Sep 21 2010 10:35:44 home.tar
6      1697952 Sep 21 2010 10:36:02 securedesktop-ios-3.1.1.45-k9.pkg
7       415956 Sep 21 2010 10:36:14 sslclient-win-1.1.4.176.pkg
Ali
Bronze
Hi Ali,
Add "telephony-service" into the router configuration.
If your IOS requires acceptance of EULA, it will ask you to do so after you add "max-dn X" and "max-ephone Y".
Boris
_____ Please rate helpful posts Пожалуйста оценивайте полезные сообщения
Hall of Fame Super Red
Re: SRST License upgrade
Hi Ali,
Check out this recent thread in addition to the good tips from Boris (+5)
https://supportforums.cisco.com/thread/2123996
Cheers!
Rob
634
