SRST Logs
Is there any command to check the logs when the SRST was enabled?
I tried using ccm-manager fallback-mgcp and show ccm manager but it only display last enabled.
I want all the logs at least 1 month log when SRST got enabled due to outage
During SRST failover there
During SRST failover there are a lot of log messages generated. You should make sure the buffer is large enough.
I want to see last time when
I want to see last time when did SRST occurred ;for complete month.
If you type show log and it
If you type show log and it doesn't go back far enough then you must make your logging buffer is larger to capture the event. There are not features or commands you can type into the router to show last SRST failover. I meant for future use you may want to adjust the buffer.
53
