10-08-2008 06:48 AM - edited 03-15-2019 01:48 PM
Is there a limit based on router model as to how many phones can register to the router in the instance of SRST? Specifically I'm looking for the differences between a 2811 and a 2821.
Thanks.
Solved! Go to Solution.
10-08-2008 06:57 AM
Good morning!
To specifically answer your question, with SRST v7, the 2811 will support up to 35 SRST phones, and the 2821 will support up to 50.
The full list of phones per router for SRST can be found here, on Table 2:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps2169/data_sheet_c78-485221.html
I hope this helps! If you found this post helpful, please rate it.
John
10-08-2008 06:57 AM
Good morning!
John
10-08-2008 07:06 AM
That's exactly was I was looking for! Thanks.
Post rated.
Greg
