Community Member
SRST MGCP PRI
SRST is confirmed working, each phone seems to be registering fine. Inbound calls work fine as well, however, outbound when the first digit is dialed '9' it immediately gives a busy signal. Any advice on this is greatly appreciated. Thanks!
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
port 0/2/0:23
dial-peer voice 101 pots
description Emergency Services
destination-pattern 911
port 0/2/0:23
forward-digits 3
dial-peer voice 102 pots
destination-pattern 9911
port 0/2/0:23
forward-digits 3
dial-peer voice 103 pots
description Local Calls 10 Digit
destination-pattern 9[2-9]..[2-9]......
port 0/2/0:23
forward-digits 10
dial-peer voice 104 pots
description Long Distance
destination-pattern 91[2-9]..[2-9]......
port 0/2/0:23
forward-digits 11
dial-peer voice 105 pots
description International
destination-pattern 9011T
port 0/2/0:23
prefix 011
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts ringing 30
ip source-address 172.16.96.1 port 2000
max-ephones 36
max-dn 72 dual-line
access-code pri 9 direct-inward-dial
voicemail 97064471399
no huntstop
call-forward busy 97064471399
call-forward noan 97064471399 timeout 20
moh Kenny-G-Track-1.wav
multicast moh 239.1.1.1 port 16384 route 172.16.96.1 10.1.1.1
time-zone 13
VIP Purple
Re: SRST MGCP PRI
Do you have one of the following depending on your version of IOS?
For Cisco IOS® Software Release 12.3(13)T or earlier:
R(config)#call application alternate default
For Cisco IOS® Software Release 12.3(14)T or later:
R(config)#application
R(config-app)#global
R(config-app-global)#service alternate Default
Hope this helps. If so, please rate the post.
Brandon
Community Member
Re: SRST MGCP PRI
Double check and found that it is in the config... Is there anything else?
Thanks!
VIP Purple
Re: SRST MGCP PRI
How about "ccm-manager fallback-mgcp"?
Brandon
Community Member
Re: SRST MGCP PRI
Here is most of the config, which does have the ccm-manager fallback-mgcp.
application
global
service alternate default
controller T1 0/2/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
interface Loopback0
description MoH for SRST
ip address 10.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.252
encapsulation dot1Q 252
ip address 172.16.239.5 255.255.255.0
ip pim sparse-dense-mode
interface FastEthernet0/1
description Connection to LAN
ip address 172.16.96.1 255.255.240.0
duplex full
speed auto
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
router eigrp 100
network 172.16.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 172.16.239.1
no ip http server
no ip http secure-server
ip tacacs source-interface FastEthernet0/1
logging history size 500
logging trap critical
logging 172.16.16.48
snmp-server community backoff RO
snmp-server community anyone RW
snmp-server location Appling Main Data Closet
snmp-server contact Information Technology
snmp-server enable traps tty
snmp-server enable traps frame-relay multilink bundle-mismatch
tacacs-server host 172.16.16.47
tacacs-server directed-request
tacacs-server key xxx
control-plane
voice-port 0/2/0:23
echo-cancel coverage 32
voice-port 0/1/0
voice-port 0/1/1
ccm-manager redundant-host 172.17.16.2
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 172.17.16.3 172.17.16.2
ccm-manager config
mgcp
mgcp call-agent 172.17.16.3 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
no mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/1
mgcp bind media source-interface FastEthernet0/1
mgcp profile default
sccp local FastEthernet0/1
sccp ccm 172.17.16.2 identifier 2 priority 2 version 4.1
sccp ccm 172.17.16.3 identifier 1 priority 1 version 4.1
sccp
sccp ccm group 100
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 10 register CFB000ab82d4ba9
dspfarm profile 10 conference
description Remote_Site_Conferencing
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
shutdown
service mgcpapp
destination-pattern 9T
direct-inward-dial
timeouts ringing 30
max-ephones 36
max-dn 72 dual-line
no huntstop
time-zone 13
vm-integration
pattern direct 2 CGN *
pattern ext-to-ext no-answer 5 FDN * CGN *
pattern ext-to-ext busy 7 FDN * CGN *
pattern trunk-to-ext no-answer 4 FDN * CGN *
pattern trunk-to-ext busy 6 FDN * CGN *
Re: SRST MGCP PRI
As your pots dial-peers already have a trunk access code, the command 'access-code pri 9 direct-inward-dial' under call-manager-fallback is not necessary.
Please try removing the command and see if this helps.
Allan.
532
