VIP Super Bronze
SRST MOH From FLASH..Done Evrything I know..Yet....
I am trying to implement srst MOH from flash for my customer. I have configured evrything as I have done in the past but this time no joy.
I have done the ff:
1. configured loopback interface
2. enable ip pim sparse-dense mode on loopback interface, gig0/0 and gig 0/1 interface
3. enable Multicast MOH on audio source and MRGL
4. Configured G711 for multicast MOH
5. configured Multicast MOH on srst router and loaded MOH to flash
attached is the relevant config
2. When I do a show ccm-manager music-on-hold
I get this
SWIPCR01#show ccm
SWIPCR01#show ccm-manager mus
SWIPCR01#show ccm-manager music-on-hold
Current active multicast sessions : 0
SWIPCR01#
show call active voice | include RemoteMedia
I get this...
SWIPCR01#
SWIPCR01#show call active voice | include RemoteMedia
RemoteMediaIPAddress=0.0.0.0
RemoteMediaPort=0
SWIPCR01#
SWIPCR01#
A show ephone summary displays
SWIPCR01#show ephone summa
SWIPCR01#show ephone summary
hairpin_block:
Max 0, Registered 0, Unregistered 0, Deceased 0 High Water Mark 0, Sockets 0
ephone_send_packet process switched 0
Max Conferences 8 with 0 active (8 allowed)
Skinny Music On Hold Status
Active MOH clients 0 (max 320), Media Clients 0, B-ACD Clients 0
File beautifultango.ulaw.wav type WAVE Media_Payload_G711Ulaw64k 160 bytes
Moh multicast on 239.1.1.1 port 16384 via 172.26.208.1
via 172.26.216.254
via 172.26.208.121
via 172.26.208.117
A debug ephone moh shows this
Apr 24 10:33:09.641: MoH route If Loopback1 46 172.26.208.1 via 172.26.208.1
Apr 24 10:33:09.641: MoH route If GigabitEthernet0/0 ETHERNET 172.26.216.254 via 172.26.208.118
Apr 24 10:33:09.641: MoH route If GigabitEthernet0/1 ETHERNET 172.26.208.121 via ARP
Apr 24 10:33:09.641: MoH route If GigabitEthernet0/0 ETHERNET 172.26.208.117 via ARP
SWIPCR01#
Apr 24 10:33:14.757: MoH route If Loopback1 46 172.26.208.1 via 172.26.208.1
Apr 24 10:33:14.757: MoH route If GigabitEthernet0/0 ETHERNET 172.26.216.254 via 172.26.208.118
Apr 24 10:33:14.757: MoH route If GigabitEthernet0/1 ETHERNET 172.26.208.121 via ARP
Apr 24 10:33:14.757: MoH route If GigabitEthernet0/0 ETHERNET 172.26.208.117 via ARP
SWIPCR01#
from the above, it is obvious that Multicast is not working. Why I do not know...
I looked at CCM trace and I can see the follwoing: n(CCM trace attached)
From the trace , I can see audio source id of 1 been selected which is correct...
04/24/2009 10:28:17.246 CCM|MohDControl - handleMohSuccess - Call Id = 43114191 AudioSourceID = 1 MuticastFlag =
However, I can see CCM telling IP phones to listen to multicast on Ip=16843247, port 16384.
The port is correct, but im not sure of the IP..it should be 239.1.1.1
04/24/2009 10:28:17.246 CCM|MohDControl - handleMohSuccess - Sent out Allocate MOH Response CallId=43114191, TransferMode=9, Ip=16843247, Port=16384, CapCount=1, AudioSourceID = 1 MuticastFlag =
Please guys what do you think.
In this setup, my router does not have an interface in the phone subnet. I have enabled ip igmp snooping on the switches with no luck. I even enabled ip multicast routing on the router with no luck.
CCM is located across the WAN over an MPLS circuit hence, we cant configure multicast routing.
What can I do..
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Re: SRST MOH From FLASH..Done Evrything I know..Yet....
Guys, any ideas?
When I did a show ip mroute count, this is what I get
SWIPCR01#
SWIPCR01#sh ip mroute count
IP Multicast Statistics
2 routes using 760 bytes of memory
1 groups, 1.00 average sources per group
Forwarding Counts: Pkt Count/Pkts(neg(-) = Drops) per second/Avg Pkt Size/Kilobits per second
Other counts: Total/RPF failed/Other drops(OIF-null, rate-limit etc)
Group: 224.0.1.41, Source count: 1, Packets forwarded: 0, Packets received: 972
Source: 172.26.208.1/32, Forwarding: 0/0/0/0, Other: 972/0/972
Should the group not be displaying 239.1.1.1 ?
Hi.
what happen if you try to force the IP multicast traffic with the
"ip igmp static-group 239.1.1.1" command under both g0/0 and g0/1 interfaces ?
Are the data multicasted (sh ip mroute command) ?
Hope this help...
VIP Super Bronze
Thanks for the post. But nothing happens and the sh ip mroute count still displays 224.0.1.41
Silver
Do you not need to create the MOH in the CCM as the same as the local SRST source The phones know about the MOH address from their TFTP download only?
VIP Super Bronze
Multicast MOH has been configured on CCM with the multicast IP address and increment by IP...I am not sure I understand waht you are asking
VIP Super Bronze
Any ideas please..Nic, Java, Gozanlez????
Enable multicast in audio source, server, MRG. Set hop count to 1...
Pls check the configuration for your scenerio from the following checklists:
A. Unicast G711 everywhere
1. Create region for MoH. G711 with all other regions.
2. Do not enable multicast in audio source, server, MRG
3. Enable only G711 in service parameter (Default)
B. G711 multicast everywhere
2. Enable multicast in audio source, server, MRG. Set hop count to 5.
4. Enable multicast in infrastructure (igmp snooping in switches, pim sparse-dense in routers)
C. G711 multicast everywhere, remote site uses MoH from local SRST flash
2. Enable multicast in audio source, server, MRG. Set hop count to 1.
4. Enable multicast in HQ and Remote LAN infrastructure (igmp snooping in switches, pim sparse-dense in routers), Disable multicast in WAN infrastructure.
5. Enable SRST MOH feature from flash.
6. Enable loopback interface in SRST router for PSTN users to hear MoH.
D. G711 multicast at HQ, G711 unicast at Remote
5. Create two MRG, one with multicast enabled for HQ and one with no mulitcast for BR1.
E. G711 unicast at HQ site, G729 unicast at remote
1. Enable Service parameter for G711 and G729
2. Use the HQ device pool for MOH server (assuming HQ device pool uses g729 for remote)
3. Do not enable multicast
F. G711 multicast at HQ, g729 multicast at remote
3. Enable multicast in audio source, server, MRG
G. g729 unicast at remote using transcode
1. Enable only G711 in service parameter
2. Put MoH server in HQ device pool (assuming HQ uses G729 for remote)
3. Add a transcoder to MRGL of MoH server
I. HQ uses G711 multicast, remote uses G729 unicast, all PSTN uses hear tone on hold
1. Use HQ device pool for MoH server
2. Enable multicast on Audio source and server.
3. Create 2 MRG, one with multicast, one without multicast
4. Enable g711 and g729 in the service parameter
5. Create a third MRG and MRGL with no MOH and apply that directly to gateways
VIP Super Bronze
Thanks for this. I have done everything here. My case is SRTS Multicast MOH from flash. I enabled ip igmp snoopin on the switches that the Phones are connected to.
CCM is placed in a remote location across an MPLS network (clustering over WAN setup)
Do I need to enable ip igmp snooping on the switches that CCM is connected to also?
Because I have enabled igmp snooping on switches where IP phones are connected to and pim sparse dense mode on routers, yet It has not worked.
No I think u only need to enable igmp snooping on the switch where phones are connected as call manager is not reveiving that multicast traffic anyways since you have not enabled multicasting on the rouyer connecting Call manager and the SRST site ( since its not required as u only need to play MOH from the router flash for remote side phones only).
Moreover dead air seems like these is some issue with the file taht u are trying to play from the flash. pls check that file or try using some other file..
Moreover also make sure that multicast stream is successfully reaching from the router to the phones.
Make sure that multicasting is enabled on all the L3 devices between the router and phones.
Futher try taking the help from some switching Engineer to get your multicasting checked.
I agree with you. It may be a problem with the audio file. Did you try with another one ?
With that file, did you try the static-group command under the gigabit interfaces ? Even if there are some issues with multicast routing, with this command, you should see the entry within the mroute table... If you don't see, I would think of internal problem with the multicast source, and in your case, have you ever try with a default file (provided by Cisco) ?
VIP Super Bronze
My problem is that I hear "dead air" I am sure this is a multicast routing issue..How do I troubleshoot multicast routing issues.
In a scenario like mine where I have SRST catalyst 3750 switches (With IP phones connecting to them)>gateway>MPLS WAN>WAN Router>CORE SW>CCM
Do I need to enable igmp snooping on all the switches including the switch CCM is connected to?
Bronze
Do you see the PIM neighbors when you put in this command?
sh ip pim neighbor
VIP Super Bronze
ALL,
I thought I should give a feedback on the resolution to this problem.
Here are the things which I did to resolve the issues
1. ADD a MRGL with a multicast MOH resource to the SRST gateway. I had this configured on the phones but not on the gateway
2. Configured ip pim sparse-dense mode on the switch ports that connect to the router
3. Configure "ip multicast-routing distributed" on the switches
Thanks for all your help.
929
