SRST Multicast MOH works for T1 but not for FXO
We have a remote site running 12-4-24.T configured for SRST Multicast MOH. It works well for our LD calls going over ds0-group 1, since I can do a show ccm-manager music-on-hold and see the packets incrementing. When a call comes in over the FXO local trunks then the caller gets TOH and the show ccm-manager music-on-hold does not see any active sessions. I have included a portion of the config and outputs. Does anyone see anything I have missed?
Re: SRST Multicast MOH works for T1 but not for FXO
Attached is the configuration and debug output
Here is the attachment
Hi, i had a problem like the one you describe and it seems to be the incomming dialpeer, try creating an incomming dialpeer for those fxo ports as you did for the t1, maybe it works.
Thanks for the reply. The issue turned out to be a codec issue for the fxo ports.
mserwon Can you tell me how
mserwon
Can you tell me how you fix it? I'm having the same issue.
thanks.
192
