SRST not working
Here is my config... Can anyone see why this would not work. IOS is 12.4, SRST is 3.3
Green
Re: SRST not working
Config looks good;
ccm-manager fallback-mgcp
service alternate default are configured
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_configuration_guide_chapter09186a008086d1e3.html#wp1351962
Waht behaviour you are getting?
i believe you need to define "max-ephones" and "max-dn" under telephony service.
here is a working config.
call-manager-fallback
secondary-dialtone 9
max-conferences 6 gain -6
transfer-system full-consult
ip source-address 10.229.129.2 port 2000
max-ephones 30
max-dn 64
dialplan-pattern 1 .......... extension-length 4
transfer-pattern 9T
default-destination 8650
voicemail 8950
alias 1 8610 to 8650
time-zone 5
please rate helpful posts.
Mike
After it is configured on the router, you have to configure it on CUCM. Setup the SRST profile, add it to the device profile you want. Reset and reboot all devices in that device profile. This will then push out the SRST information to the IP phones. When the connection is lost to CUCM at the IP phone, it will have the SRST information on the device and fail to the router configured in the SRST profile.
290
