Community Member
SRST Phone registration
I have configured MGCP SRST on my gateway, running 12.4, but the phones wont register to it.
I copied the config from another gateway/cucm and cant see any difference that would stop it wotking.
If I do "sh ephone" on the working system it shows the mac addresses and "un regstered" as I would expect.
If I do this on the non working system it shows nothing.
If I try to add aphone manually as below
srst_router#conf t
srst_router(config)#ephone ?
<1-150> Ethernet phone tag
srst_router(config)#ephone 1
ephone_array index 1 has empty entry
can anyone tell me what the error means ?
thanks
1 REPLY
Community Member
Re: SRST Phone registration
Can you post the configuration under "call-manager-fallback"?
Have you configured "max-ephones" and "max-dn"?
183
