SRST Problem with "no requested circuit (44)" Error
Hi all,
I have configured SRST on a gateway and for some reason it's not working since an IOS upgrade. The current version is
151-4.M3 on a 3845 router.
The scenario is a MGCP gateway, configured with SRST and a T1. With the MGCP everything works fine, but when it goes to SRST it is not working, it gives me the message "no requested circuit (44)" for outgoing calls and there isn't any q931 logs (the T1 is up and running fine, channels look ok). We can see it is matching the right dial-peer but it's not going out.
We tried these dial-peers:
dial-peer voice 911 pots
destination-pattern 911
port 0/0/0:23
forward-digits 3
dial-peer voice 9911 pots
service mgcpapp
destination-pattern 9911
port 0/0/0:23
forward-digits 3
dial-peer voice 110 pots
destination-pattern 9T
direct-inward-dial
port 0/0/1:23
GENERIC:
SetupTime=*00:51:02.241 UTC Tue Mar 13 2012
Index=47377
PeerAddress=7965
PeerSubAddress=
PeerId=20123
PeerIfIndex=371
LogicalIfIndex=370
DisconnectCause=2C
DisconnectText=no requested circuit (44)
ConnectTime=0
DisconnectTime=*00:51:20.421 UTC Tue Mar 13 2012
CallDuration=00:00:00 sec
CallOrigin=2
ReleaseSource=7
InternalErrorCode=1.1.181.1.25.114
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0xF00CB6F2 0x6E3811E1 0xBA1ECCAE 0x1DB1328E]
IncomingConnectionId=[0xF00CB6F2 0x6E3811E1 0xBA1ECCAE 0x1DB1328E]
CallID=47421
Port=50/0/123 (47421)
BearerChannel=50/0/123.0
TxDuration=0 ms
VoiceTxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
CallerName=6506647965
CallerIDBlocked=False
LongDurationCallDetected=no
LongDurCallTimeStamp=
LongDurCallDuration=
OriginalCallingNumber=7965
OriginalCallingOctet=0x0
OriginalCalledNumber=
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=7965
TranslatedCallingOctet=0x0
TranslatedCalledNumber=
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GwCollectedCalledNumber=913367676767T
GwReceivedCallingNumber=7965
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x0
MlppServiceDomainNW=0 (none)
MlppServiceDomainID=0
PrecedenceLevel=-1 (PRECEDENCE_LEVEL_NONE)
*Mar 13 01:11:35.789: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0001
    Bearer Capability i = 0x8090A2
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA98397
        Exclusive, Channel 23
    Calling Party Number i = 0x2181, '6506647965'
        Plan:ISDN, Type:National
    Called Party Number i = 0x80, '13367676767'
        Plan:Unknown, Type:Unknown
*Mar 13 01:11:35.845: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8001
    Cause i = 0x82AC - Requested circuit/channel not available
Any help will be appreciated
Thank you,
11 Replies 11
Chris Deren
Do you have the following defied:
application
 global
   service alternate Default
Chris
Hi Cris,
Thank you for your reply.
Yes, I have that parameter configured on the voice gateway.
Have you confirmed the number of channels available to you as the no channel request looks like the lack of channels. Maybe change the channel order to test?
In normal operation (i.e. non-SRST) what channel is used? Do calls go out via channel 23 as in your debug or channel 1?
It's possible this is a fractional PRI and chanel 23 is not available.
You could try:
Interface serial0/0/1:15
isdn bchan-number-order ascending interface serial0/0/1:15
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi Aaron,
Just one question so I can understand better the SRST.
When it uses SRST, Is it the gateway T1 configuration come from T1 parameters of the CUCM?
In the Call Manager is configured "Channel Selection Order" "Botton Up"
Look like all channels are ok:
show voice port sum
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/1:23        01  xcc-voice   up    dorm none     none     y
0/0/1:23        02  xcc-voice   up    dorm none     none     y
0/0/1:23        03  xcc-voice   up    dorm none     none     y
0/0/1:23        04  xcc-voice   up    dorm none     none     y
0/0/1:23        05  xcc-voice   up    dorm none     none     y
0/0/1:23        06  xcc-voice   up    dorm none     none     y
0/0/1:23        07  xcc-voice   up    dorm none     none     y
0/0/1:23        08  xcc-voice   up    dorm none     none     y
0/0/1:23        09  xcc-voice   up    dorm none     none     y
0/0/1:23        10  xcc-voice   up    dorm none     none     y
0/0/1:23        11  xcc-voice   up    dorm none     none     y
0/0/1:23        12  xcc-voice   up    dorm none     none     y
0/0/1:23        13  xcc-voice   up    dorm none     none     y
0/0/1:23        14  xcc-voice   up    dorm none     none     y
0/0/1:23        15  xcc-voice   up    dorm none     none     y
0/0/1:23        16  xcc-voice   up    dorm none     none     y
0/0/1:23        17  xcc-voice   up    dorm none     none     y
0/0/1:23        18  xcc-voice   up    dorm none     none     y
0/0/1:23        19  xcc-voice   up    dorm none     none     y
0/0/1:23        20  xcc-voice   up    dorm none     none     y
0/0/1:23        21  xcc-voice   up    dorm none     none     y
0/0/1:23        22  xcc-voice   up    dorm none     none     y
0/0/1:23        23  xcc-voice   up    dorm none     none     y
Best Regards,
No - when registered to CUCM using MGCP, it uses the CUCM parameters.
WHen in SRST, it's basically running like CME/a normal H.323 gateawy and only locally configured commands take effect.
Re: channels 'OK' they will appear up, but the service provider may reject calls if you haven't paid for the channel.
Try changing the channel selection order, if you get the same error on channel 1 then we'll think again, if it works then you're making progress.
Aaron
Hi Aaron,
Thank you for the explanation.
I've checked the voice gateway and the calls are using the channel, 0/0/1:23. Because it's the first channel CUCM will use to complete calls, it's quick to test that channel.
It looks the channel is fine when using MGCP.
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x657      14DE 0x716DB090 0/0/1:23.23      0/1:1  *           g711ulaw 0/0
Best Regards,
OK - can you post a q931 debug of the succesful call when registered to CUCM?
*Mar 19 14:50:37.171: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8  callref = 0x0116
                Standard = CCITT
        Called Party Number i = 0x80, '17503999958'
*Mar 19 14:50:37.335: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8116
*Mar 19 14:50:40.851: ISDN Se0/0/1:23 Q931: RX <- PROGRESS pd = 8  callref = 0x8116
        Progress Ind i = 0x8488 - In-band info or appropriate now available
*Mar 19 14:50:40.899: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8  callref = 0x8116
        Progress Ind i = 0x8482 - Destination address is non-ISDN
*Mar 19 14:50:40.935: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0116
Can you post your full config, do you by any chance have 'call fallback active' defined, if so remove it.
Chris
Hi Cris,
I cannot post the full config due to customer privacy, but I can show you any part of the config (changing numbers, IPs and names).
The call manager fallback is configured (working all other sites that way).
call-manager-fallback
max-conferences 12 gain -6
transfer-system full-consult
ip source-address 10.220.190.5 port 2000 strict-match
max-ephones 250
max-dn 300
transfer-pattern .T
default-destination 5900
moh music-on-hold.au
