03-19-2012 03:23 AM - edited 03-16-2019 10:12 AM
Hi all,
I have configured SRST on a gateway and for some reason it's not working since an IOS upgrade. The current version is
151-4.M3 on a 3845 router.
The scenario is a MGCP gateway, configured with SRST and a T1. With the MGCP everything works fine, but when it goes to SRST it is not working, it gives me the message "no requested circuit (44)" for outgoing calls and there isn't any q931 logs (the T1 is up and running fine, channels look ok). We can see it is matching the right dial-peer but it's not going out.
We tried these dial-peers:
dial-peer voice 911 pots
destination-pattern 911
port 0/0/0:23
forward-digits 3
dial-peer voice 9911 pots
service mgcpapp
destination-pattern 9911
port 0/0/0:23
forward-digits 3
dial-peer voice 110 pots
destination-pattern 9T
direct-inward-dial
port 0/0/1:23
GENERIC:
SetupTime=*00:51:02.241 UTC Tue Mar 13 2012
Index=47377
PeerAddress=7965
PeerSubAddress=
PeerId=20123
PeerIfIndex=371
LogicalIfIndex=370
DisconnectCause=2C
DisconnectText=no requested circuit (44)
ConnectTime=0
DisconnectTime=*00:51:20.421 UTC Tue Mar 13 2012
CallDuration=00:00:00 sec
CallOrigin=2
ReleaseSource=7
InternalErrorCode=1.1.181.1.25.114
ChargedUnits=0
InfoType=speech
TransmitPackets=0
TransmitBytes=0
ReceivePackets=0
ReceiveBytes=0
TELE:
ConnectionId=[0xF00CB6F2 0x6E3811E1 0xBA1ECCAE 0x1DB1328E]
IncomingConnectionId=[0xF00CB6F2 0x6E3811E1 0xBA1ECCAE 0x1DB1328E]
CallID=47421
Port=50/0/123 (47421)
BearerChannel=50/0/123.0
TxDuration=0 ms
VoiceTxDuration=0 ms
FaxTxDuration=0 ms
CoderTypeRate=None
NoiseLevel=0
ACOMLevel=0
SessionTarget=
ImgPages=0
CallerName=6506647965
CallerIDBlocked=False
LongDurationCallDetected=no
LongDurCallTimeStamp=
LongDurCallDuration=
OriginalCallingNumber=7965
OriginalCallingOctet=0x0
OriginalCalledNumber=
OriginalCalledOctet=0x80
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x0
TranslatedCallingNumber=7965
TranslatedCallingOctet=0x0
TranslatedCalledNumber=
TranslatedCalledOctet=0x80
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x0
GwCollectedCalledNumber=913367676767T
GwReceivedCallingNumber=7965
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x0
MlppServiceDomainNW=0 (none)
MlppServiceDomainID=0
PrecedenceLevel=-1 (PRECEDENCE_LEVEL_NONE)
*Mar 13 01:11:35.789: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0001
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x2181, '6506647965'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '13367676767'
Plan:Unknown, Type:Unknown
*Mar 13 01:11:35.845: ISDN Se0/0/1:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8001
Cause i = 0x82AC - Requested circuit/channel not available
Any help will be appreciated
Thank you,
03-19-2012 06:01 AM
Do you have the following defied:
application global service alternate Default
Chris
03-19-2012 06:15 AM
Hi Cris,
Thank you for your reply.
Yes, I have that parameter configured on the voice gateway.
03-19-2012 06:18 AM
Have you confirmed the number of channels available to you as the no channel request looks like the lack of channels. Maybe change the channel order to test?
03-19-2012 06:19 AM
In normal operation (i.e. non-SRST) what channel is used? Do calls go out via channel 23 as in your debug or channel 1?
It's possible this is a fractional PRI and chanel 23 is not available.
You could try:
Interface serial0/0/1:15isdn bchan-number-order ascending interface serial0/0/1:15
Principal Engineer at Logicalis UK
Please rate helpful posts...
03-19-2012 07:02 AM
Hi Aaron,
Just one question so I can understand better the SRST.
When it uses SRST, Is it the gateway T1 configuration come from T1 parameters of the CUCM?
In the Call Manager is configured "Channel Selection Order" "Botton Up"
Look like all channels are ok:
show voice port sum
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/1:23 01 xcc-voice up dorm none none y
0/0/1:23 02 xcc-voice up dorm none none y
0/0/1:23 03 xcc-voice up dorm none none y
0/0/1:23 04 xcc-voice up dorm none none y
0/0/1:23 05 xcc-voice up dorm none none y
0/0/1:23 06 xcc-voice up dorm none none y
0/0/1:23 07 xcc-voice up dorm none none y
0/0/1:23 08 xcc-voice up dorm none none y
0/0/1:23 09 xcc-voice up dorm none none y
0/0/1:23 10 xcc-voice up dorm none none y
0/0/1:23 11 xcc-voice up dorm none none y
0/0/1:23 12 xcc-voice up dorm none none y
0/0/1:23 13 xcc-voice up dorm none none y
0/0/1:23 14 xcc-voice up dorm none none y
0/0/1:23 15 xcc-voice up dorm none none y
0/0/1:23 16 xcc-voice up dorm none none y
0/0/1:23 17 xcc-voice up dorm none none y
0/0/1:23 18 xcc-voice up dorm none none y
0/0/1:23 19 xcc-voice up dorm none none y
0/0/1:23 20 xcc-voice up dorm none none y
0/0/1:23 21 xcc-voice up dorm none none y
0/0/1:23 22 xcc-voice up dorm none none y
0/0/1:23 23 xcc-voice up dorm none none y
Best Regards,
03-19-2012 07:08 AM
No - when registered to CUCM using MGCP, it uses the CUCM parameters.
WHen in SRST, it's basically running like CME/a normal H.323 gateawy and only locally configured commands take effect.
Re: channels 'OK' they will appear up, but the service provider may reject calls if you haven't paid for the channel.
Try changing the channel selection order, if you get the same error on channel 1 then we'll think again, if it works then you're making progress.
Aaron
03-19-2012 07:21 AM
Hi Aaron,
Thank you for the explanation.
I've checked the voice gateway and the calls are using the channel, 0/0/1:23. Because it's the first channel CUCM will use to complete calls, it's quick to test that channel.
It looks the channel is fine when using MGCP.
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x657 14DE 0x716DB090 0/0/1:23.23 0/1:1 * g711ulaw 0/0
Best Regards,
03-19-2012 07:24 AM
OK - can you post a q931 debug of the succesful call when registered to CUCM?
03-19-2012 07:49 AM
*Mar 19 14:50:37.171: ISDN Se0/0/1:23 Q931: TX -> SETUP pd = 8 callref = 0x0116
Standard = CCITT
Called Party Number i = 0x80, '17503999958'
*Mar 19 14:50:37.335: ISDN Se0/0/1:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x8116
*Mar 19 14:50:40.851: ISDN Se0/0/1:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8116
Progress Ind i = 0x8488 - In-band info or appropriate now available
*Mar 19 14:50:40.899: ISDN Se0/0/1:23 Q931: RX <- CONNECT pd = 8 callref = 0x8116
Progress Ind i = 0x8482 - Destination address is non-ISDN
*Mar 19 14:50:40.935: ISDN Se0/0/1:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0116
03-19-2012 09:45 AM
Can you post your full config, do you by any chance have 'call fallback active' defined, if so remove it.
Chris
03-19-2012 10:46 AM
Hi Cris,
I cannot post the full config due to customer privacy, but I can show you any part of the config (changing numbers, IPs and names).
The call manager fallback is configured (working all other sites that way).
call-manager-fallback
max-conferences 12 gain -6
transfer-system full-consult
ip source-address 10.220.190.5 port 2000 strict-match
max-ephones 250
max-dn 300
transfer-pattern .T
default-destination 5900
moh music-on-hold.au
