Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
SRST query
Do we need to do anything on the dial-peers on a H323 gateway to enable SRST?
Bronze
Re: SRST query
Hi Abijhit,
Not exactly, just ensure that you have one to reach the outside world...
dial-peer voice 9 pots
destination-pattern 9T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
Then you need to configure call-manager-fallback.
A full guide to configuring SRST can be found here http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_configuration_guide_book09186a0080861003.html
Dave
Re: SRST query
Hi Dave,
Thanks again. Is it necessary to install any separate SRST package on the router? I thought having a router model with IOS supprting SRSt was enough.
Abhijit.
Bronze
Re: SRST query
Abhijit,
No, SRST is integrated into Cisco IOS releases. You can use the Feature Navigator to find out which versions of SRST are supported in each IOS.
Dave
153
