Community Member
SRST Question
If you have a router that supports 100 ip phones in SRST mode but have 120 phones, is there a way of deciding which phones will not register?
regards
colin
1 ACCEPTED SOLUTION
Community Member
Re: SRST Question
Create two device pools on CCM/CUCM and assign one of the device pools with the appropriate SRST reference and leave the other one set to default. From there you are able to create your Cor list's as needed on your SRST device and know that the appropriate devices are able to register.
Green
Re: SRST Question
You can use max-phones
or ACLs to restrict specific IP/subnets or not add the SRST reference for the Phones u dont want to register in SRST mode
Community Member
Re: SRST Question
Community Member
Re: SRST Question
can this be acheived by manually entering the ephone-dn is the vg ?So at the time the fall back happns only these dn get registered....
Faizal
Super Bronze
Re: SRST Question
Yes - that would work.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Re: SRST Question
thank you both for your reply
regards
colin
195
