Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
SRST question
When in SRST mode, is it possible to define witch phones do register with the SRST gateway? For example I have 60 phones in the same region, as define in the CallManager (4.2), but the license for the SRST is only to 48 phones, and I would like to be able to define witch phones continue to work until the WAN link is re-establish. Is this possible and how?
1 ACCEPTED SOLUTION
Re: SRST question
Yes, Simply create two device pools and one SRST reference for this remote site. Assign DP1 to SRSTREF1 and DP2 - set the SRST reference to disable.
Assign the phones that require SRST to DP1 and Assign the phones that do not require SRST to DP2.
Sankar
PS: please remember to rate posts!
1 REPLY
Re: SRST question
Sankar
112
