SRST Refresh
Hi All,
We are using SRST 12.4(15T) along with CCM ver 6.0. The problem which we are facing is that when CCM goes down , IP phones working switch over to SRST router but in SETTINGS-DEVICE CONFIGURATION under IP phone , IP phone still shows CCM as ACTIVE & SRST AS STANDBY which takes a long time to get refresh.Sometimes we need to reset the IP phone also.Same was happening from SRST to CCM switchover but we have configured keepalive as 10 seconds under call-manager-fallback in router & is working fine.
Is there any option in CCM version 6.0 where we can change this paramter?
regds,
aman
Hall of Fame Super Silver
Re: SRST Refresh
So, is the problem simply the display on the phone or is there any functional issue?
Chris
Re: SRST Refresh
Hi Chris,
the problem is only with the display. No functional issue is there .
regds,
aman
Re: SRST Refresh
Seems like a firmware bug to me. What is your firmware verison?
Chris
Re: SRST Refresh
Hi chris,
I will check & get back to you. But other sites are working fine.
regds,
aman
Re: SRST Refresh
Hi ,
The version which we are using is SIP70.8-3-1S(Jar70SIP.8-3-0-50.sn)
regds,
aman
149
