srst secondary-dialtone does not support dialing via # ??
The Company I am working with uses # for outside calls (as opposed to say a 9) with CUCM.  The problem is that when a remote site goes into SRST, the newer routers running Fallback 8.1 do not support the # even where the dial-patterns are already configured to do so and otherwise work properly under H.323.  Older routers do support the #.  Using a # for secondary-dialtone is also not supported which makes me think Cisco dropped support for the #.
Does anyone now if Cisco actually discontinued support of the # key for "outside" dialing or am I missing something here.
Everyone's tags (4)
Roger,
SRST 8.1 should be IOS 15.
There is a known issue for secondary-dialtone command while using any caracter not being 0-9.
You might want to look at this.
CSCtn51761
Please rate this post if it was helpful.
Luis Ramirez
excellent, that is what I suspected!
Roger
332
