Community Member
SRST support for a branch with 450 end users?
It seems like once you go past the 3845 SRST gateway the SRST reference material is a wee bit of a challenge. Does anyone know what size SRST gateway would support a head count for a centralized remote office of 450?
Any feedback and/or links to the info would be very much appreciated.
Best regards,
Vicky
Community Member
Re: SRST support for a branch with 450 end users?
Ok scratch this. I found the link to answer my question. The 3845 gateway can support up to 720 end users in SRST mode. In case anyone needs the link, pls see below.
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80169812.pdf
Cheers.
Vicky
Hi Vicky,
Good to know that you found the answer on your own :) (+5 for the same).
-> Sushil
102
