SRST Timer
Hello Guru,
after MGCP fallback to SRST, what is the timer the SRST router back to CUCM? immediately? or some delay?
if it is immediately and if WAN link flaps, will the T1 D channel flap as well?
Re: SRST Timer
Once the connection with the call manager is reestablished
the ip phones cancel their registeration to the SRST and reregister with the call manager
also could you plz show the 2nd ask in more details?
thanks
Re: SRST Timer
thx for the reply
the mgcp gateway will register back immediately after IP connectivity to CUCM servers restored
however, IP phones don't because the default 120 second
so during the 120 seconds, no outgoing calls via gateway, this is too bad
other thing, if the IP connectivity between CUCM and gateway are flapping, so the PRI D channels will be up/down, this is too bad as well
Bronze
Re: SRST Timer
If you plan to use the default time interval between keepalive messages, which is 30
seconds, you do not have to perform this task.
otherwise,
SUMMARY STEPS
1. call-manager-fallback
2. keepalive seconds
3. exit
Re: SRST Timer
virverma
I am thinking we updated in same time, I did take a look the timer setup under call-manager-fallback, but it is for the communicate between SRST router and IP phones, not between SRST and CUCM
Bronze
Re: SRST Timer
SRST will take over after 3 incomplete ntfy messages are sent to the call manger from the router. this is not configurable.
Re: SRST Timer
can I ask the SRST router stay there for certain time before switch back to CUCM?
Bronze
Re: SRST Timer
sorry for late reply,
in cucm, in gateway configuration page there is option for
swithcback timing and swithcback uptime-delay
Re: SRST Timer
unfortunately, the way you introduced not working
I tried different combination, including config
ccm config
ccm config server
mgcp restart-delay
ccm switchback uptime-delay
880
