SRST Translation Profiles
I am configuring SRST on a 3825 running 12.4(15)XZ1.
I am trying to configure translation profiles under the call-manager-fallback section but the translations do not seem to be coming into effect before dial-peers are matched. This happens with both incoming and outgoing calls.
voice translation-rule 2
rule 1 /^4\(...\)/ /902076914\1/
rule 2 /^5\(...\)/ /902076915\1/
rule 3 /^6\(...\)/ /902076916\1/
rule 4 /^1\(...\)/ /902085451\1/
rule 5 /^8\(...\)/ /902078618\1/
voice translation-profile SRST_Outbound
translate called 2
secondary-dialtone 9
max-conferences 12 gain -6
transfer-system full-consult
limit-dn 7911 2
limit-dn 7936 2
limit-dn 7941 2
timeouts interdigit 3
ip source-address 10.180.82.129 port 2000 strict-match
max-ephones 350
max-dn 960 dual-line preference 6
system message primary CUCM Down, SRST is Active
dialplan-pattern 1 73.... extension-length 4
no huntstop
translation-profile outgoing SRST_Outbound
time-format 24
date-format dd-mm-yy
I am not sure why the dial-peer matching occurs before the translation profile is applied. I am sure that I have used this type of configuration in the past.
The details of the SRST service are shown below:
show call-manager-fallback
CONFIG (Version=7.0(0))
Version 7.0(0)
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
max-ephones 350
dspfarm units 0
dspfarm transcode sessions 0
no huntstop
no huntstop channel
voicemail 902076916999
cnf-file location: system:
cnf-file option: PER-PHONE-TYPE
network-locale[0] US (This is the default network locale for this box)
network-locale[1] US
network-locale[2] US
network-locale[3] US
network-locale[4] US
user-locale[0] US (This is the default user locale for this box)
user-locale[1] US
user-locale[2] US
user-locale[3] US
user-locale[4] US
srst mode auto-provision is OFF
srst ephone template is 0
srst dn template is 0
srst dn line-mode single
time-format 24
timezone 0 Greenwich Standard Time
call-forward busy 902076916999
call-forward noan 902076916999 timeout 12
no transfer-pattern is configured, transfer is restricted to local SCCP phones only.
alias 1 3500 to 3502 preference 1
alias 2 3500 to 3503 preference 2
alias 3 3500 to 3504 preference 3
alias 4 3500 to 3581 preference 4
alias 5 3500 to 3511 preference 5
keepalive 30 auxiliary 30
timeout interdigit 3
timeout busy 10
timeout ringing 180
timeout transfer-recall 0
timeout ringin-callerid 8
timeout night-service-bell 12
caller-id name-only: enable
Limit number of DNs per phone:
12SP: 56
7902: 56
7905: 56
7906: 56
7910: 56
7911: 2
7912: 56
7920: 56
7921: 56
7931: 56
7935: 56
7936: 2
7937: 56
7940: 56
7941: 2
7941GE: 56
7942: 56
7945: 56
7960: 56
7961: 56
7961GE: 56
7962: 56
7965: 56
7970: 56
7971: 56
7975: 56
7985: 56
anl: 56
ata: 56
bri: 56
CIPC: 56
vgc-phone: 56
Log (table parameters):
max-size: 150
retain-timer: 15
transfer-digit-collect new-call
local directory service: enabled.
Extension-assigner tag-type ephone-tag.
Silver
Re: SRST Translation Profiles
From the config. you are trying to keep the ability to dial extension numbers to other sites when in SRST hence the translations? What are the Dial-Peers which the calls are matching? What digist do teh users enter, ar you show they are still not dialling 9, 0 as the pstn access code and hence dial out?
Thanks for the response. The transalated numbers should match the dial-peer below:
dial-peer voice 100 pots
translation-profile outgoing DDI_Outbound
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
However, debugging the dial-peer matching shows the system trying to match using the untranslated 4 digit number - e.g. 1313 - and failing to find a matching dial peer.
Silver
You shoud not need the translation on the Dial-Peer since you added it under the fallback
Sorry the dial peer config is what is actually running at the moment. The translation profile was applied under call-manager-fallback and not on the dial peer when I did my testing.
Hall of Fame Super Silver
Change the TP in fallback to:
translation-profile incoming SRST_Outbound
from
Chris
It is a different behavior when you apply the translation-profile under call-manager fallback. The incoming and outgoing commands are related to the IP phone. The incoming command changes the parameters of calls that come from the IP phone. The outgoing command changes the values of calls that go out of the router to the IP phone. So since you have configured incoming under SRSTmode it will be used for outbound calls.”
669
