SRST trouble
I'm setting up SRST on my MGCP gateway (2610). I've pretty much set everything up but I'm having problems with inbound calling (outbound works fine). The first issue I'm having is the tranlation rule I set up doesn't, for some reason, seem to work. When I run "test translation-rule 1 xxxxxx" I get "Translation Rule 1 is not defined" as if I don't have one created. The other issue I'm seeing is that when I run "debug voice ccapi inout" and make an inbound call, besides getting a second dial tone, the debug shows the wrong dial-peer being referenced (the MGCP dial peer.)
Anyhow, here is my command set for my translation profile and dial-peer. Please help me resolve, I rate helpful posts;
voice translation-rule 1
rule 1 /.+/ /3000/
voice translation-profile srst
translate called 1
dial-peer voice 5000 pots
translation-profile incoming srst
incoming called-number .
destination-pattern 9T
direct-inward-dial
port 1/0/0
-Shikamaru
1 ACCEPTED SOLUTION
Bronze
Re: SRST trouble
Do you have just fxo ports on this gateway? if so it might be better to go for h.323 instead of mgcp.
That way you can do the translation on the outbound dial-peer, so you will have two outbound dial-peers, one pointing to call manager and the other to ext 3000.
HTH, Avner.
Bronze
Re: SRST trouble
First of all, to test the voice translation-rule, use the 'test voice translation-rule' command, the one you were using is for testing the 'old' translation rules.
As for MGCP taking control of your inbound calls, have you configured mgcp fallback to srst? if so, does it sense that the fallback mode is active? ('show ccm-manager fallback').
HTH, Avner.
Re: SRST trouble
Avner,
When I typed the "test voice translation-rule" command, it works fine, thank you. Now, for the second part when I check fallback mode, this is my output;
WANRouter261001#show ccm-manager fallback-mgcp
Current active Call Manager: None
MGCP Fallback mode: Enabled/ON
Last MGCP Fallback start time: 17:41:06 UTC Mar 1 1993
Last MGCP Fallback end time: None
So, it seems as though SRST is engaged at this point. Just a thought; is there any requirement for an FXO to be able to support SRST mode? My FXO is not v2, I don't know if that matters.
-Shikamaru
Bronze
Re: SRST trouble
Ohh, I had PRI in the back of my head, if it is FXO, is it controlled by mgcp at all?
If not then put a connection plar on the voice port.
If it is used for mgcp and for srst, then your translation rule should be /\(.*\)/ /3000/ , since there is no called number.
HTH, Avner.
Re: SRST trouble
Yes it is. Sorry I forgot to mention. Do I need to add something to its config?
-Shikamaru
Bronze
Re: SRST trouble
HTH, Avner.
Re: SRST trouble
Avner,
The translation doesn't seem to work (same result).
When you say there is "no called number", do you mean that the data recieved from the analog line is different then if the call was made on a DID of a PRI?
-Shikamaru
Bronze
Re: SRST trouble
Yes, i don't expect the same from fxo.
Can you run 'debug voip dialpeer' and call in while in srst mode? post the results so we can try to figure out what is going on.
Re: SRST trouble
Avery,
Here is the output from dialin.
-Shikamaru
WANRouter261001#
*Mar 1 19:39:35.852: Inside dpMatchCore:
*Mar 1 19:39:35.852: destination pattn: expanded string:
*Mar 1 19:39:35.865: %CALL_CONTROL-6-APP_NOT_FOUND: Application mgcpapp in dial-peer 999100 not fou
nd. Handing callid 31 to the alternate app default.
Bronze
Re: SRST trouble
hmm, looks like it match the mgcp dial-peer even when mgcp is down, can you post the mgcp dial-peer config? do you have more then 'application mgcpapp' and 'port 1/0/0' in there?
Re: SRST trouble
Yes, I think we are close to the issue. When I removed the mgcp dial-peer that the output was referencing, the call did go through. Now I have to figure out how the dial-peer will stop being used in an SRST scenario (weird, I've never run into this.)
Here are all of the dial peers.
dial-peer voice 999100 pots
application mgcpapp
port 1/0/0
dial-peer voice 999101 pots
application mgcpapp
port 1/0/1
direct-inward-dial
port 1/0/0
-Shikamaru
Bronze
Re: SRST trouble
well, since there is no calling or called, we do inbound matching acording to the port command, and we prefer the first dial-peer added to the config.
Try to add back the dial-peer you removed, it should still work since it will be added after dial-peer 5000.
Just make sure that dial-peer 5000 will be the first one listed when you exec the 'show run' command.
Let me know, Avner.
Re: SRST trouble
Yeah, the heart of the issue is the order of the dial peers. SRST works great until I take it out of SRST mode, then the dial-peer I made for SRST remains active and its the MGCP dial peers that aren't being used.
The MGCP dial peers are placed onto the gateway by CallManager when the gateway registers and downloads its config. I don't suppose there is a way for the gateway to "lose" its MGCP dial peers if it is in SRST mode (i.e; it can't register with the CM?)
-Shikamaru
Bronze
Re: SRST trouble
HTH, Avner.
Re: SRST trouble
I just might. Thanks, Avner.
-Shikamaru
Re: SRST trouble
Okay, I have figured out how to resolve this issue. To recap;
- One MGCP gateway with two FXO ports
- CallManager 4.2(3)
- Inbound calling doesn't work when gateway is in SRST mode. Outbound calling works fine.
The issue was that inbound calling was being handled by the MGCP dial peer which, in an SRST situation, is irrelevant. I was able to resolve this problem by configuring "connection plar opx extensionnumber" on the FXO voice-port. For some reason, this syntax has no priority when the gateway is not in SRST mode. In SRST, it trumps the dail peers and takes priority for inbound calling.
This solution is good in situations when inbound calling is forwarded to an Auto Attendant during normal operation but want calls forwarded to the receptionist extension during outages.
-Shikamaru
Re: SRST trouble
Shikamaru
Can you post the config you used? I am having the same issue.
Re: SRST trouble
The only way I found that would resolve this issue is to set up a "plar opx" syntax on the voice port. Otherwise, the MGCP dial peer is always used as a priority no matter what. It's a weird work around, but it works.
-Shikamaru
Re: SRST trouble
Shikamaru,
I tried excatly that. It still tries to match the MGCP
did you have to match your plar opx to any other peer?
What IOS are you running?
Re: SRST trouble
No, the PLAR goes to the DN. I'm running advanced IP services on a 2610.
-Shikamaru
344
