SRST + Unity Express Problem
jonwoloshyn
Level 4
Level 4
I've got a bit of a head scratcher (for me anyway).
Setup is as follows. Centralized CM5 cluster. Remote gateway with Unity Express and SRST configured. Normal operation is MGCP.
I have the following dial-peers set up for Unity Express for SRST mode:
dial-peer voice 1 voip
description Local NM-CUE (CME) Voicemail
destination-pattern 3030
session protocol sipv2
session target ipv4:172.17.0.99
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2 voip
description Local NM-CUE (CME) Auto Attendant
destination-pattern 3050
codec g711ulaw
no vad
dial-peer voice 3 voip
description Local NM-CUE (CME) Greeting Management System
destination-pattern 3040
codec g711ulaw
no vad
When SRST becomes active, I can dial into any of those 3 extensions from a phone without issue.
The main AA number is 555-555-8321. This is not the same as the AA dial-peer which is 3050. So I have translation rules and dial-peers set up as follows:
voice translation-rule 100
rule 1 /^15555558322/ /2305/
rule 2 /^8322/ /2305/
rule 3 /^15555558323/ /2318/
rule 4 /^8323/ /2318/
rule 5 /^15555558324/ /2309/
rule 6 /^8324/ /2309/
rule 7 /^15555558321/ /3050/
rule 8 /^8321/ /3050/
rule 9 /^15555558325/ /2308/
rule 10 /^8325/ /2308/
voice translation-profile SRST-1
translate called 100
dial-peer voice 83215 voip
translation-profile incoming SRST-1
destination-pattern 1555555832[1-5]
session target ipv4:172.17.0.101
incoming called-number 1555555832[1-5]
dial-peer voice 983215 voip
translation-profile outgoing SRST-1
destination-pattern 832[1-5]
no vad
So from the translation rules we see that an incoming call to 15555558321 gets translated to 3050.
The problem is I get a busy signal.
When I dial 8321 from a phone, I get a busy signal as well.
When I dial 8322, the phone with extension 2305 rings.
I'm not sure what I am doing wrong or even if this is normal behaviour.
Any help would be great on this.
Jon Woloshyn
I can't see the entire configuration, so i'm going to go out on a limb and ask the following questions:
Do you have the following information in the configuration:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
Fallback to H323
int faste 0/0.X
h323-gateway voip interface
h323-gateway viop bind src X.X.X.X
Call application alter default
Have you tried using number expressions instead of Translation profiles?
num-exp 8321 3050
num-exp 15555558321 3050
10 Replies 10
Rajesh Revuru
Level 4
Level 4
Do you have translation-profile incoming on your POTS dial-peer too? I only see it is applied to VOIP dial-peer
no vad
I don't think I need a pots dial-peer for that.
The default dial-peer is handling all the incoming calls:
dial-peer voice 10 pots
incoming called-number .
direct-inward-dial
port 0/0/0:23
After matching on this dial-peer the call will match the following dial-peer as an outbound dial-peer.
It then hits the translation patterns and the called number gets modified.
Then it has to match a dial-peer for the modified called-number.
Works great for the dynamic dial-peers set up by SRST. Won't work for my dial-peers set up for Unity Express. Might have something to do with SIP but I'm not sure.
When I call in to 1555-555-8322, the correct extension rings so I don't think it is a problem with the inbound dial-peer.
You may be running into a redirection problem. The debugs in my last post will tell us that. You mention that if you call 8322 from outside it rings the extension fine, but does it go to VM with no issue?
No problems going to voice-mail.
kelvin.blair
Level 5
Level 5
Can you run these debugs and post the output?
debug voip dialpeer inout
debug voice ccapi inout
debug voice translation
Here are the logs. From dialing 8321 from 2313.
voice service voip
Fallback to H323
int faste 0/0.X
num-exp 8321 3050
Kelvin,
number expansion did the trick. Thank you very much.
Cool!.. Glad to hear it is working now with the number expansions statements. The orginal problem seems to be with the translation pattern and how you are translating the digits.
Hi All
I understand CUE works with SRST. I need to confirm that it is Cisco/TAC supported
