09-14-2009 07:04 AM - edited 03-15-2019 07:44 PM
Our Setup, hub site with voice PRI and POTS lines with CallXpress voicemail system and remote sites with IP Phones and POTS lines.
When the remote site goes into SRST mode everything works except the VM-Integration. When the user press the message key or when a call does not get answered it goes out via PSTN using POTS lines to the hub site voicemail backdoor number but fail to take the caller to the user's mailbox, instead it is playing the general greeting. Any help.
09-15-2009 11:04 PM
In order to allow SRST user access to voice mail, configure these parameters on the SRST gateway:
call-manager-fallback
dialplan-pattern 1 9195014... extension-length 4
voicemail 914085011600
call-forward busy 914085011600
call-forward noan 914085011600 timeout 10
Note: This example includes the full E164 number (which includes 9) and assumes the PSTN delivers full 10-digit numbers.
09-16-2009 05:05 AM
Sorry for not providing the exact picture. We are using the CME SRST fallback configuration as follows:
dial-peer voice 9999 pots
destination-pattern 912123334444*....
port 0/1/0
forward-digits extra inband
prefix 112123334444,,,,,,*
num-exp 8400 912123334444
telephony-service
srst mode auto-provision all
srst dn template 1
max-ephones 36
max-dn 50
ip source-address 172.16.11.5 port 2000
timeouts interdigit 5
system message primary "DR Mode:Call Help Desk"
voicemail 8400
max-conferences 4 gain -6
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp 7960 Sep 04 2009 00:04:20
vm-integration
pattern direct * CGN
pattern ext-to-ext no-answer * FDN
pattern ext-to-ext busy #* FDN
pattern trunk-to-ext no-answer #* FDN
pattern trunk-to-ext busy #* FDN
ephone-dn-template 1
call-forward busy 8400
call-forward noan 8400 timeout 3
ephone-dn 1
number 8813
label 8813
description 2123331111
name 2123331111
Still with this configuration VM-integration does not take the caller to the users voicemail box in SRST condition.
09-30-2009 06:40 AM
Once you arrive the auto attendant,
you'll need to dial the extension plus ...
in some systems, it is #2 or as determined
so you will need to modify when no answer from ext to ext or trunk to ext fo FDN plus #2
pattern ext-to-ext no-answer * FDN #2
plz check and feed back
