Community Member
SRST & VoiceMail
have voicemail XXXX in call-manager fallback. When in SRST, gets fast busy when hit messages button. Also cannot dial internal 4 digit extensions, which I suspect is related. Any help is appreciated.
Re: SRST & VoiceMail
please post the whole config, is the VM going to be reached thru PSTN or is it local?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
VoiceMail is local. Here is the dial-peer and call-manager-fallback.
dial-peer voice 1 pots
description Outbound SRST LD
destination-pattern 91..........
port 2/0:23
prefix 1
dial-peer voice 3 pots
description Outbound SRST Intl
destination-pattern 9011............
port 2/0:23
prefix 011
dial-peer voice 6020 voip
session target ipv4:172.19.64.130
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 4 pots
description Outbound 10 Digit Local
destination-pattern 9[2-9].........
port 2/1:23
dial-peer voice 5 pots
description Inbound
direct-inward-dial
port 2/1:23
dial-peer voice 6 pots
direct-inward-dial
port 2/0:23
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
ip source-address X.X.X.X port 2000
max-ephones 200
max-dn 200 dual-line
system message primary phone system in Backup Mode
dialplan-pattern 1 3234366... extension-length 4 no-reg
dialplan-pattern 2 3234366... extension-length 4 no-reg
voicemail 3000
call-forward busy 3000
call-forward noan 3000 timeout 4
time-zone 5
date-format dd-mm-yy
if the VM is local you need to configure CME and the VM ports to register locally, also the VM system to failover to the CME if primary fails
javalenc
java
Community Member
CM is remote, version 4.2.3,
Unity is local, v4.2.1
164
