Community Member
SRST vs dial-peer
Why dial-peer that respond for incoming call are in down state and as I suppose for this reason SRST doesn't work?
command "no shut" - doesn't help
Here is the screenshot.
Community Member
Re: SRST vs dial-peer
screen
Community Member
Can you paste your sh run config of the router.
-vishwesh
Community Member
voice-port 0/0/0:15
cptone RU
ccm-manager fallback-mgcp
ccm-manager redundant-host XXXXX
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server XXXXX
ccm-manager config
mgcp
mgcp call-agent XXXXXXX 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/1.10
mgcp bind media source-interface GigabitEthernet0/1.10
mgcp profile default
dial-peer voice 1 pots
tone ringback alert-no-PI
destination-pattern 80.........
no digit-strip
direct-inward-dial
port 0/0/0:15
dial-peer voice 2 pots
destination-pattern 82.......
no digit-strip
direct-inward-dial
port 0/0/0:15
dial-peer voice 3 pots
destination-pattern 0[1234]
no digit-strip
direct-inward-dial
port 0/0/0:15
dial-peer voice 2222 pots
shutdown
destination-pattern 0T
port 0/0/0:15
dial-peer voice 4 pots
destination-pattern [234].....
no digit-strip
direct-inward-dial
port 0/0/0:15
dial-peer voice 80 pots
incoming called-number .
direct-inward-dial
port 0/0/0:15
call-manager-fallback
max-conferences 8 gain -6
ip source-address XXXXXX port 2000
max-ephones 48
max-dn 96
transfer-pattern 0.
transfer-pattern 0..
transfer-pattern 2.....
transfer-pattern 3.....
transfer-pattern 4.....
transfer-pattern 82.......
transfer-pattern 80..........
316
