SRST vs UCME with SRST
In a centralized environment where the branches are remotely connected to Call Manager Cluster in a data center then what would be the appropriate solution as a backup for the branches in case they lose the WAN connectivity. SRST only or UCME with SRST.
I can't find any good doc on CCO where Cisco can explain in which deployment model UCME with SRST would be required or recommended.
Thx
Re: SRST vs UCME with SRST
generally the same
but if u want more spicific features to be kept for each phone with UCME with srst u can do it with more flexibility
hope this helpful
Hi Abbas,
Few points you need to take care -
CME in SRST mode does not supports Meet-Me conferencing.
SRST does not supports Unity Express.
CME in SRST mode will support lesser phones as compared to SRST for example 3825 in CME in SRST mode will support 240 phones while in STST mode it'll support 720 phones.
-> Sushil
SRST does support Unity Express... here are some facts about CME in SRST mode; the big ones being that CME in SRST mode requires more configuration, gets you more features, but supports less phones for a given platform:
- IP phones re-home to CME in event of CallManager failure & have access to advanced CME telephony features
- less phones supported
- No support for Vg248 registration during fallback
- Lack of support for “alias” command
- Support for Cisco Unity at remote sites
- Pickup Groups, Hunt Groups, B-ACD, Call Park, Softkey templates, paging
- No support for secure voice in SRST mode
- Requires more complex configuration
Hi MARKUS,
Thanks for pointing out.
Actually CME in SRST mode does not supports Unity Express.
Best Practices for Unified CME in SRST Mode
•Use SRST if deploying Cisco Unity Express at remote sites; Unified CME in SRST mode does not support Cisco Unity Express.
From SRND 6.1, page 50 SRND.
-> Sushil
Hall of Fame Super Silver
To summirize everyeone's responses, it depends on requirements.
If the customer only cares about getting phones calls and being able to dial out and some limited functionallity under SRST condition then legacy SRST will suffice.
If they require more features, i.e. hunting, pickup groups, call park, etc then CME as SRST would be a good solution (I personally love it).
HTH,
Chris
i agree with u Chris
but i think adding all IP phones with thiser MACs and ddetails long with CME/SRST while with SRST mor esimple right ?
You dont have to do anything manually if you dont want to in CME as SRST you can utilize srst mode auto-provision.
Chris
hi Chris
could u please describe how auto-provision works
thank you
i have read it today thanks anyway :)
by the way the only option i confused with is the provesion none
none-Does not include information for learned ephones or learned ephone-dns in the running configuration. Use this keyword when you want Cisco Unified CME to provide SRST fallback services for Cisco Unified Communications Manager
didnt got it !!! i mean this part only ( Use this keyword when you want Cisco Unified CME to provide SRST fallback services for Cisco Unified Communications Manager)!
389
