Community Member
SRST with fractional ISDN CUCMBE 6
I am carrying out an install with CallManager 6 Business edition and run into a hurdle.
As the customer only has 15 Channels on the ISDN30 E1, I have shut down the channels using the maintenance option in the advance tab of the system parameters; this works fine when the gateway is in MGCP mode. The problem I have is when the gateway falls into SRST mode, as it attempts to put the outbound call out on channel 30 and therefore the call fails. Does anyone know of a fix for this.
1 ACCEPTED SOLUTION
Green
Re: SRST with fractional ISDN CUCMBE 6
Use under the ISDN interface the
"isdn b-channel ascending" command
Bronze
MGCP fractional T1 is not fully support in Cisco callmanager , better try changing to H.323 gateway for fractional T1.
Green
312
