SRST with Hunt Pilots
Problem.
I have a Hunt Pilot which has a Hunt List with Remote Sites IP Phones in it.
Problem is if that site goes into SRST, how would you suggest I route the calls out he PSTN to that sites main number?
The reason i have this scenario, is I have internal Translation Patterns for people dialing 10 digits that transform to the HP for that site.
So
10-Digit <translation> --> Hunt Pilot --> Remote Phones.
I was thinking of setting the Hunt Pilots RNA to the 10 Digit PSTN number (Giving a different CSS which avoids the Translation Pattern). But then Legitimate calls to that site would Loop back in if no on answers when SRST isnt going on.
Any thoughts?
Re: SRST with Hunt Pilots
Also, is there anyway to make a Hunt Pilot call Unregistered devices? Or forward to their CFUR?
Did anyone ever come across/resolve this issue as I am trying to implement the same thing?
I got it to work but i couldnt have my 10 digit translations.
I take it your 10 digit transaltions are to force on-net dialing? Did you get around this another way?
Correct. So I either have to remove them permanent or remove them temporarily when a site goes down
593
