SRST
In field SRST Reference Name. Can I use the name same without DNS server?
2 ACCEPTED SOLUTIONS
Re: SRST
without DNS your phones won't be able to reach the SRST router, either you add a DNS server or use IP address for reference
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Re: SRST
Yes, this is simply a descriptive name and is only locally significant. The IP Address field determines the SRST router that phones register with.
Hope this helps. If so, please rate the post.
Brandon
Re: SRST
javalenc
java
Re: SRST
Brandon
108
