SRST
Dear All
Is there any way for implementing SRST on cisco H323 gateway instead of mgcp?
regards
Re: SRST
Yes, the config is pretty much the same, this link should get you going:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f8b31.shtml
Re: SRST
Yes, you can use SRST with an H.323 gateway. You would basically just need to configure phone support. See the following link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cusrst/admin/srst/configuration/guide/srs_wlan.html#wp1331691
This is assuming that you have proper dial peers in place. You would also need to consider how calls get routed to voicemail, AAs, etc. when SRST is active.
Hope this helps.
Brandon
201
