SRST
I'm attempting to get SRST to work with a 7940 phone, 1751v router, and a 3500 switch.
I've got the call-manager-fallback configured according to the SRST 3.0 Admin Guide, however I don't think it's working properly.
The phone can successfully get an address from the router, but it just keeps trying to "Configuring CM List" or "opening IP Address" of an IP that's not even in this subnet.
I was expecting to see "CM Fallback Service Operating" on the screen, but can't get it.
I don't have a this router/gateways setup in our active Call Managers. Would this cause a problem? Does it need to be setup and then when the link is cut it THEN properly falls back to SRST?
Here's the running config from the router:
version 12.2
hostname Router
boot system flash c1700-sv8y-mz.122-15.ZJ2.bin
logging queue-limit 100
no logging console
enable password
memory-size iomem 15
clock timezone PST -7
ip subnet-zero
no ip domain lookup
no ip dhcp conflict logging
ip dhcp excluded-address 172.16.3.1
ip dhcp excluded-address 172.16.3.254
ip dhcp pool AZ
network 172.16.3.0 255.255.255.0
option 150 ip 172.16.3.1
ip cef
voice call send-alert
voice rtp send-recv
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
codec preference 3 g729r8
voice class h323 1
h225 timeout setup 3
no voice hpi capture buffer
no voice hpi capture destination
fax interface-type fax-mail
mta receive maximum-recipients 0
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.10.3.1 255.255.255.0
ip helper-address 10.10.1.5
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 172.16.3.1 255.255.255.0
interface Serial0/0
no ip address
encapsulation frame-relay
no ip mroute-cache
load-interval 30
shutdown
no fair-queue
frame-relay traffic-shaping
frame-relay ip rtp header-compression
h323-gateway voip interface
interface Serial0/0.16 point-to-point
description phoenix
ip address 172.1.1.9 255.255.255.252
no ip mroute-cache
frame-relay interface-dlci 16 CISCO
class qos-1536k
frame-relay ip tcp header-compression
router bgp 19007
no synchronization
bgp log-neighbor-changes
no auto-summary
ip classless
no ip forward-protocol udp netbios-dgm
ip route 0.0.0.0 0.0.0.0 172.1.1.10
no ip http server
snmp-server community az RO
snmp-server enable traps tty
call rsvp-sync
voice-port 1/0
input gain -1
echo-cancel coverage 32
echo-cancel suppressor
no vad
no comfort-noise
timeouts interdigit 2
voice-port 1/1
input gain -1
no vad
no comfort-noise
mgcp profile default
dial-peer cor custom
dial-peer voice 91 pots
preference 1
destination-pattern 6T
max-conferences 4
ip source-address 172.16.3.1 port 2000
max-ephones 24
max-dn 48
access-code fxo 9
Router#
1 REPLY
Gold
Re: SRST
On the CallManager, under Device Pool, you need this Router selected as SRST Reference.
The CallManager configuration would be:
1. Define SRST Reference
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmcfg/b02srst.htm
2. Assign this SRST Reference to the Device Pool
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmcfg/b02devpl.htm
Once this is done, you will have to reset the IP Phones and confirm that under the list of CallManagers mentioned in Network Settings (Settings|Network Settings) you see the SRST Router as the last available CallManager.
Hope this helps
352
