SRTP on H323 gateway IOS v 15.1
Aaziz AMHAOUCH
Hi all,
I have a problem with SRTP command on cisco  Gateway with IOS 15.5, this version don't permit this command:
gw(config)# voice service voip
gw(config-voi-serv)#srtp
but cisco's documents report that this version support srtp command, is this a bug or this version doesn't support it ?
Any help will be appreciated,
B.R.
13 Replies 13
vemanyam
SUMMARY STEPS
    1. enable
    2. configure terminal
    3. dial-peer voice tag voip
    4. destination-pattern string
    5. session protocol sipv2
    6. session target ipv4: destination-address
    7. incoming called-number string
    8. codec codec
    9. end
    10. dial-peer voice tag voip
    11. Repeat Steps 4, 5, 6, and 7 to configure a second dial peer.
    12. srtp
    13. codec codec
    14. exit
please refer:
http://www.cisco.com/en/US/docs/ios-xml/ios/voice/cube_proto/configuration/xe-3s/asr1000/voi-srtp-rtp-int.html
Thank you Babu,
We don't use "session protocol sipv2" in dial-peer and when we try srtp command we get: % Unrecognized command
B.R.
What is the exact version you are using on your GW ?
Mr. Veera has explained you the way to enable srtp per dial peer basis.. it does not matter if it is sip or h323..
You can try it..
Cheers !
Piyush
Hi B.R.,
Can u share the show version and show license feature output from your router?
Also, share licnese detail.
you need to have Universal image with security license PAK for srtp on ISR G2 router to work.For ISR series , u need to have Advanced Enterprise services image.
regds,
aman
Hi all,
This is the version of the IOS:
GW#sh version
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9_NPE-M), Version 15.1(1)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 19-Jul-10 03:07 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
GW uptime is 5 days, 20 hours, 43 minutes
System returned to ROM by reload at 12:50:09 UTC Tue Sep 10 2013
System restarted at 12:51:38 UTC Tue Sep 10 2013
System image file is "flash0:c2951-universalk9_npe-mz.SPA.151-1.T1.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 483328K/40960K bytes of memory.
Processor board ID FCZ144421G9
3 Gigabit Ethernet interfaces
2 ISDN Basic Rate interfaces
4 Voice FXO interfaces
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2951/K9          FCZ144421G9
Technology Package License Information for Module:'c2951'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9_npeEvaluation    securityk9_npe
uc            uck9          Permanent     uck9
data          None          None          None
HI Aziz,
I think  u need to have UniversalK9 image which supports secure unified communications.
You are using npe [no payload encryption] image which does not support.
Can u try downloading the image and generate eval license , test whether the srtp command is coming or not?
regds,
aman
Hi B.R.,
Any updates ?
regds,
aman
Thank you for your interest, well my colleague said that they tried C2951-UNIVERSALK9 image first and the srtp command didn't work, then they installed securityk9_npe evaluation license and also it didn't work.
I can't find a cisco document that explain the prerequists of this configuration !!
BR
Hi All,
We tested the UniversalK9 image and it also doesn't work !!
BR,
Aziz
Hi Aziz,
Can u share the show version and show licnese feature/detail  output from router ?
regds,
aman
Hi Aman,
this is the show commands :
GW#sh vers
GW uptime is 2 weeks, 6 days, 20 hours, 50 minutes
export@cisco.com.
License Info:
License UDI:
Device#   PID                   SN
data          None          None          None
GW#sh license feature
Feature name             Enforcement  Evaluation  Subscription   Enabled
ipbasek9                 no           no          no             yes
securityk9_npe           yes          yes         no             yes
uck9                     yes          yes         no             yes
datak9                   yes          yes         no             no
gatekeeper               yes          yes         no             no
LI                       yes          no          no             no
ios-ips-update           yes          no          yes            no
SNASw                    yes          yes         no             no
GW#sh license detail
Index: 1        Feature: SNASw                             Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
        License Count: Non-Counted
        License Priority: None
        Store Index: 4
        Store Name: Evaluation License Storage
Index: 2        Feature: datak9                            Version: 1.0
        Store Index: 2
Index: 3        Feature: gatekeeper                        Version: 1.0
        Store Index: 3
Index: 4        Feature: ipbasek9                          Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
        Store Index: 0
        Store Name: Primary License Storage
Index: 5        Feature: securityk9                        Version: 1.0
        License State: Active, Not in Use, EULA accepted
        License Priority: Low
        Store Index: 2
Index: 6        Feature: securityk9_npe                    Version: 1.0
            Evaluation period left: 5  weeks 4  days
            Expiry date: Nov 09 2013 12:31:08
        Store Index: 0
Index: 7        Feature: uck9                              Version: 1.0
        Store Index: 1
Index: 8        Feature: uck9                              Version: 1.0
        License State: Inactive
        Store Index: 1
Hi Aziz,
show version still shows npe image.
you need to have image univerasalk9 without npe.
regds,
aman
