SRV records
I configured Srv records in CUCM  as per docs,still i am facing the problem while logging in jabber client i am getting a error "Cannot communicate to the server",but i can able to login through ip address..in SIP information for SRV i tried with destination adress/domain name,but still i cannot resolve this issue,suggest me on this!!!
Any idea about this issue
Are you using username@domain
Are you using username@domain.com and are the SRV records in the domain.com that is being used to log into Jabber?
Please rate useful posts.
yes we are using domain name
yes we are using domain name to loggin  into jabber
Have you tried what Jaime
Have you tried what Jaime suggested? Can you post your results here?
nslookup
set type=srv
_cuplogin._tcp.domain.com
_cisco-uds._tcp.domain.com
 George,Let me try & give u
George,
Let me try & give u the results.
You could be hitting BugId
You could be hitting BugId CSCup30905
If you're using Jabber with auto discovery for purely IM&P (i.e. no softphone) then auto discovery doesn't work. The fixes are either upgrade to CUCM 10.something or upgrade to a Jabber client that does not currently exist.
GTG
Please rate all helpful posts.
I'd start by using nslookup
I'd start by using nslookup to make sure you're actually resolving them and that they're properly configured.
java
if this helps, please rate
www.cisco.com/go/pdi
90
