SSHv1 / SSHv2 support for Cisco IOS on VG224
We are trying to configure the SSHv1 or SSH v2 on VG224 with vg224 Software (vg224-I6S-M), Version 12.4(12)(vg224-i6s-mz.124-12), however there doesnt seem to be any supported commands on the IOS release.
Anyone tried SSH configuration on VG224 analog gateways, and which IOS release to be used?
Thanks.
Re: SSHv1 / SSHv2 support for Cisco IOS on VG224
The IOS you're using does not support SSH
It needs the IP SUBSET/IPSEC 64 BIT/VOICE
The IOS name should contain a K9 in case it's enabled for it
IE
vg224-i6k9s-mz.124-15.T5.bin
java
if this helps, please rate
java
www.cisco.com/go/pdi
Also, would this support SSH version 1 or 2?
With the k9 image it will support both v1 and v2.
-nick
Thank you java and nick !
I am running 12.4.22.T5 and can only get SSH V1 to operate. If I specify SSH V2 I get no connection. I am using a 2048 modulus on the key. Any thoughts?
We  have the same issue too, we have IOS  vg224-i6k9s-mz.150-1.M3.bin and higher on our VG 224's .
Never able to get SSH v2 working on the them, SSH v1 works fine .
also we use a modulus 1024 key .  Some body advise ??
Indu.
1315
