ssl certificate for ccmuser (UCM 6.1)
Is there a way to use an SSL certificate other than the self-signed one for ccmuser/ccmadmin pages.
I have done this under 4.x and IIS to provide users with a more memorable site name than https://serverxyx/ccmuser (e.g. https://euro.ipt.local/ccmuser). This is in an environment where I have a trusted internal root certificate.
Mark.
Anonymous
N/A
Re: ssl certificate for ccmuser (UCM 6.1)
Steps to install the certificate from CCM:
Browse to the application on the IIS server.
When the Security Alert dialog box displays, click View Certificate.
In the Certificate pane, click Install Certificate.
Click Next.
Click the Place all certificates in the following store radio
button; click Browse.
Browse to Trusted Root Certification Authorities.
Click Next.
Click Finish.
To install the certificate, click Yes.
A message states that the import was successful.Click OK.
In the lower, right corner of the dialog box, click OK.
To trust the certificate so you do not receive the dialog box
again, click Yes.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_1_3/ccmcfg/b01intro.html
Pengke
Thanks for that - if it were a version 3/4.x it would have been very useful. Unfortuately, I'm trying to do this for version 6.1.
Did you have any success finding the correct steps. I am trying to hunt down the same procedure and have so far been unsuccessful
Brent,
Unfortunately it is not possible with UCM 6.1. I believe there is a feature request open with Cisco for this functionality. I am unsure as to whether it is available in UCM 7, as I am yet to get a hold of a copy.
Sorry I can't be more helpful.
Mark.
347
